I contacted service about replacement wipers. They told me to bring the vehicle in or go to Napa. So, looking online I found these:
They don't work. They don't have the washer fluid holes and the heating element. You need to get them from Lucid. You don't need to replace the entire wiper blade. You just need to replace the rubber insert, should only be a few dollars.I contacted service about replacement wipers. They told me to bring the vehicle in or go to Napa. So, looking online I found these:
Thank you! They weren't very good right off the bat, the rains here in CA went pretty hard about a week after I got the car (it had 25 miles on it). I'll try cleaning them and see if that does anything.
One Hundred PerCent.Actually, I think they are great. Have you truly cleaned them? You need to lift them and use a soap or APC solution and a course cloth to get road oil and grime off of them. Scrub the rubber edge. Washed wife's new Audi today and I was surprised at the oil and dirt that came off the blade and rubber when I cleaned it with a cotton cloth and APC.
And using a hydrophobic coating works wonders.
Not sure this is so. The Lucid replacement rubbers (got them from Service Center ~$16/ea.) look pretty basic, with a T -groove that slots into the arm. I bet you could just get a long refill and cut it to size. Also, make sure the plastic trim at the bottom of the windshield is flush with the glass. If it sticks up just the slightest bit it will catch the rubber edge and pull it out of the groove.You cannot use different blades on a Lucid.
You can use different inserts… I don’t think you can use a different wiper blade/arm.One Hundred PerCent.
Call service. This sounds like maybe the whole fixture needs to be replaced. Or perhaps your blade arm is bent out of shape somehow?My blade on the drivers side is leaving a constant streak on the downstroke every time. It continued doing this even after replacing the insert. It’s so bad I basically have to leave the wipers off most of the time. When the water eventually dries it leaves a horrible water streak across my sight line.
Are there any adjustments they can make to the wipers, aside from replacing the blade insert? My wipers are basically useless to me.
I don't think I'd trust that guy. I've always read to only use rubbing alcohol or glass cleaner on the blades. This seems to back that up:Apparently most wiper blades need cleaning, not replacement. Esp if they are the higher quality silicone type that Lucid seems to spec.
Hmm good point.I don't think I'd trust that guy. I've always read to only use rubbing alcohol or glass cleaner on the blades. This seems to back that up:
"Can you use WD40 to clean wiper blades?
The short answer is yes; you can use WD40 to clean wiper blades. WD40 can act as a powerful solvent, dissolving dirt and debris that has accumulated on the wiper blade. It can also help to lubricate the blade, which can improve its performance and prevent it from skipping or streaking across the windshield. However, there are some important considerations to keep in mind when using WD40 on wiper blades.
One of the most significant concerns with using WD40 on wiper blades is that it can remove the graphite and/or teflon layer from the blade. This layer is essential to the blade’s performance, keeping it gliding over the glass and silent in operation. If this layer is removed, the blade can become noisy or less effective at clearing the windshield.
Additionally, using WD40 on wiper blades can cause the rubber to deteriorate over time. WD40 can dry out the rubber, causing it to crack or split, which can affect the blade’s performance and cause it to wear out more quickly.
So, while WD40 can act as a strong effective cleaner to clean wiper blades, it is essential to use it carefully and sparingly, to avoid causing damage to the blade."
https://www.uniwiper.com.au/can-you-use-wd40-to-clean-wiper-blades/
Martin, did you ever get your question answered? I am also looking for a windshield wiper blade/adapter replacement for my 2025 AT. I'd like to know a part number, or manufacturer so I can buy them in the aftermarket.Does anyone know the size or model of the windshield wiper blades? I need to replace mine, but there's no detail in the user manual about their sizes. I've tried looking it up on Autozone and Advanced Auto Parts websites, but they have no data either.
I didn't find out the specific size. I ended up having the service center change the inserts. It seems they use fairly standard, I think from Bosch. It could probably be done yourself if you measured the size.Martin, did you ever get your question answered? I am also looking for a windshield wiper blade/adapter replacement for my 2025 AT. I'd like to know a part number, or manufacturer so I can buy them in the aftermarket.
Thanks
Sometimes this streak is caused by the rubber folding over / dislodging when it catches on the plastic trim at the bottom edge of the glass. Open the funk and look at the trim piece = it should be flush with the windshield. Push it back if it's even a tiny bit "out", and re-seat the rubber blade on the wiper.I was having an unfixable problem with the downstroke on the driver's side leaving a streak right in front of my eyes. I was told that sometimes happens on many cars as the blades get older, they start to slightly deform for some reason. The service center has to replace this because the wiper fluid and heater are integrated and it's a custom part. It cost $100 for both blades. I didn't fight them about covering it under warranty, but honestly I think it was like that pretty much from the beginning.
I have the same issue, really irritating, simple design flaw. Wish Lucid would address this.My Touring is a year old - haven't replaced the blades yet - they seem to be clearing as designed. That said, there is a design flaw (not uncommon) where the Drivers side blade flings excess washer fluid on the passenger side windshield, after the passenger side blade is most of the way down. Since that's the resting position, the remaining washer fluid sits right in the passenger (wifey's!) line of sight. Even a second, third and sometimes fourth extra wipe (without fluid) leaves the droplets, because the remaining washer fluid is still clinging to the drivers blade. First world problem, but a bit annoying - I assume it has bothered others on this forum ?
Just sold my 1993 MB 500e (W124 chassis) . . . those cars (all W124's) had a beautiful single wiper system - like a Lemans racing car. Wiper arm pivot axis was centered on the windshield, and on a cam that allowed it to move outward slightly as it moved toward each upper corner of the windshield. The design offered excellent (90% ?) sweep of the windshield (with sightlines that I would kill for in the Lucid - another topic), and never pushed water into the other blade - because there wasn't one. Aside from doing it's job well, also very cool to watch. I don't understand why other manufacturer's didn't copy it (patents?) and more perplexingly, why MB forfeited it. Maybe they couldn't take the financial hit of selling 50% fewer replacement blades ?
Non-heated: https://store.lucidmotors.com/non-heated-wiper-blades/So...it seems like we still haven't found where you can buy and swap new blades on yourself? Seems like our collective guidance is clean with isopropyl alcohol?
I have to remember how remarkably specific I need to be with my words here.
If by “remarkably specific,” you mean “specific,” then sure.I have to remember how remarkably specific I need to be with my words here.
There are no 3rd party wiper blades for Lucid. There are rubber and silicone refills you can buy online from third parties and swap out just the rubber insert. Just measure the length.So...it seems like we still haven't found where you can buy and swap new blades on yourself for a remotely reasonable price? The Lucid store ones are $40-50 per blade, which is 4-5x the cost of replacing wipers on any car I've ever owned. WTF. Seems like our collective guidance is clean with isopropyl alcohol as next best option?
