My wife and I completed our first "road trip" - Pittsburgh -> Reading PA -> ShortHills NJ -> Rehobeth DE -> Pittsburgh . . . about 1100 miles over 5 days. We averaged 3.8 for the entire trip . . . Touring on 19's with the aero inserts in place, 70% highway at 70-80mph.
My charging experience leads me to similar conclusions as Thinjake. While each charge stop created a level of anxiety, due to the points made by Thinjake, we had mostly positive charging experiences, except our last charge(s) which happened at EA stations in Frederick MD and Hagerstown MD respectively. Frederick had 150 KhW units available . . . but with others charging and whatever power limitations the station had, it was only putting out 30-50KwH. (although I saw an F150 charging at 87 on a like 150 charger. Uugghh. It estimated 1 hr 20 minutes to charge to 88%.
So we only added 10% and drove to Hagerstown. Their 350 KwH chargers kept toggling back and forth between operable / non-operable. Very frustrating. Finally, we plugged into a 150 charger - which actually started us at 175, then slowly decreased as is normal. It took < 45 minutes to charge.
I had a seasoned EV owner at an earlier stop tell me that the chargers can and will charge above their stated capacity, and (more frequently) charge well below their stated capacity - for no apparent reason. He also said that he doesn't have free charging with EA (like we do), but he generally tries EA stations first because they tend to have higher speed charging in his experience, fwiw. Go figure.
That said, all of the gushed upon qualities of the car outweigh these charging constraints, especially when there is optimism that the network(s) will continue to improve in the coming years. I may take Thinjakes ICE tactic for long trips where I don't have flexibility in charging or if I know I'm going to more rural areas where chargers are few and far between.
