I just want to install my LHCS, but I'm not going to do that until Lucid announces how everything is going to work, and whether we need additional equipment. I don't want to have my electrician come to my house twice if I can avoid it.
Exactly!I just want to install my LHCS, but I'm not going to do that until Lucid announces how everything is going to work, and whether we need additional equipment. I don't want to have my electrician come to my house twice if I can avoid it.
Well.... The Gravity also has this if you opted for the power outlets. The outlets power on my 1800 watt Coffee MachineLucid should do this ASAP. Note that its a standard feature.
"The Genesis Electrified GV70 (EV) is equipped with a Vehicle-to-Load (V2L) system as a standard feature.
This system allows you to use the car's high-voltage battery to power external electrical devices and appliances. Key details of the system include:
- Dual Power Outlets:
- Indoor: A standard 110-volt (or region-specific 3-pin) outlet is located inside the vehicle, typically in the second row or luggage area, for charging smaller electronics like laptops.
- Outdoor: An exterior V2L connector can be plugged into the charging port (located behind the front grille) to power larger equipment such as camping gear, electric grills, or coffee machines.
- Power Output: The system supports a maximum power output of approximately 3.6kW.
- Battery Management: To ensure you are not left stranded, you can set a discharge limit (typically between 20% and 100%) through the infotainment system. Once the battery hits this predefined level, the V2L system will automatically shut off."
Yeah, Gravity can do all of this. Even without the power outlets, you can also charge other EVs at a rate up to like 10kw by purchasing the Range Xchange cable from the Lucid store for the Gravity.Well.... The Gravity also has this if you opted for the power outlets. The outlets power on my 1800 watt Coffee Machine
Exactly! 1800w/plug with power or tech package for a total of 5.4kw draw, have wondered if anyone has pushed it to see if everything works as it is supposed to with that much draw on all 3 plugs simultaneously?Well.... The Gravity also has this if you opted for the power outlets. The outlets power on my 1800 watt Coffee Machine
And what could be more important than that in the event of an outage!Well.... The Gravity also has this if you opted for the power outlets. The outlets power on my 1800 watt Coffee Machine
Exactly!!!If one lives in an area with lots of blackout, V2H makes sense (although a separate generator might make more sense). If one very rarely has blackouts, then V2H might be excessive as it is expensive to automate the switch between power sources. V2L is a decent compromise to let one keep refrigerators going, etc. without the expense of automating the power delivery systems at a much lower cost (maybe a long extension cord).
Lucid's approved coffee blend is Robusto!And what could be more important than that in the event of an outage!![]()
The brew has a excellent finish, but only after you complete a medium grind.
Thank you HC for finding that, but the bag is hard to open!!
I think if you have frequent blackouts, a generator makes more sense. But for those that already have solar power without battery backup, one could easily integrate it with a home charging system at the time of installation. So this is the equivalent of a 90kWh back up battery at no additional cost. A 13.5kWh powerwall is $8000, so I'm sure you can see why many of us are anxious for Lucid to make good on a 3+ year promise.If one lives in an area with lots of blackout, V2H makes sense (although a separate generator might make more sense). If one very rarely has blackouts, then V2H might be excessive as it is expensive to automate the switch between power sources. V2L is a decent compromise to let one keep refrigerators going, etc. without the expense of automating the power delivery systems at a much lower cost (maybe a long extension cord).
Questions to you (and others who used a similar strategy for potential power loss) from Virginia where we didn't lose power, but had overnight temps in the low teens to 20's for most nights after the storm:Charged up to 92%.
ice storm due here in few hours.
We can camp in the Lucid for a few days with heat, light, entertainment/coms.
Vehicle into a home.
I'd be happy with V2L using the NACS power connector to a 240V receptacle (similar to RangeXchange). One key thing I they should include is the ability to select floating or bonded neutral. If you plug in a coffee machine (or RV) into the connector, the neutral and ground should be bonded. If you're connecting the 240V receptacle to a power inlet to the house (e.g., interlock or transfer switch), then it needs to be a floating neutral. I have a FranklinWH battery, and if I had a Ford Lightning, I'd need to sever the ground somewhere to get the system to work. Adding a bond isn't a huge deal, but removing one seems dicey.If one lives in an area with lots of blackout, V2H makes sense (although a separate generator might make more sense). If one very rarely has blackouts, then V2H might be excessive as it is expensive to automate the switch between power sources. V2L is a decent compromise to let one keep refrigerators going, etc. without the expense of automating the power delivery systems at a much lower cost (maybe a long extension cord).
You need to enter your pin, shake your fob and hope the bag doesn't need mobile service to replace the opening device....Thank you HC for finding that, but the bag is hard to open!!
Huh, I had no idea they (powerwalls) were that expensive.A 13.5kWh powerwall is $8000,
