- Nov 19, 2021
- Cupertino, CA
- Air DE-P, Gravity DE
- Air DE Number
- 241
- Gravity DE Number
- 013
- Q1BTN5Y3
I have had no issues transitioning from the Air to the Gravity. If you are used to the Air’s brake pedal, you will find Gravity feels very similar.Newer, better than average review here:
“Worrying was the glitchy software in the test cars on hand. None present had the head-up display working, and journalists driving another car reported that the lane-keep assist wouldn’t turn off despite being shown as deactivated in the driver-assist menu.
Other build-quality issues were evident. Some vehicles had comically huge panel gaps, and ours made all sorts of creaking noises that either came from the suspension or from trim pieces rubbing against each other.”
And interesting notes on the brakes:
“The brake pedal itself feels very odd. An engineer said they were aiming for a similar brake-pedal feel as a 911 GT3, but it feels more like an old Citroen.
There’s a little dead spot at the top, but once you get into the pedal, it acts more like a pressure-sensitive switch with almost no travel. It’s very unnatural and not really like a GT3’s brakes at all. That sort of works in an old Citroen DS, but in something that weighs nearly 6,000 pounds and has this much power, you want something that isn’t so vague. It saps confidence.”
Pressure plate brake pedals are a typical race car setup, but they typically require very high pedal effort to get good modulation, and they take getting used to. Interested to try this one.
This reviewer, I imagine, is not used to the Air’s brake pedal.
