- Nov 18, 2022
- Lucid Air Grand Touring
With respect to the Lucid in the I-90 Surge, are we focusing on
The whole point of discussion here is driving past 0% multiple times.
- I think we all agree that Team Lucid made some bad decisions. The out-of-charge/tow incident occurred when ~90% of the race was already covered. That said, putting the running out of charge/towing incident aside, I am wondering if there are some significant lessons RE: Lucid's charging/efficiency vis-a-vis:
- before the Lucid ran out of charge and got towed, the Taycan was already significant ahead and would have won the race amongst the EV entries regardless, correct?
- Furthermore, the Lucid wasn't exactly in second place either. It was in a cluster of 3-4 EVs behind the Taycan, and was that way for a long time before the tow incident. In other words, the Lucid wasn't a run-away 2nd place finisher right behind the Taycan.
- Yet, the specs suggest the Taycan has significantly less range than the Lucid and lower peak charging intake, correct? Does that suggest that on long road trips with need for multiple charging stops, a flatter, sustained charge curve is more important than a short high peak charge rate?
- all of the other EVs (Teslas, Hyundai, etc.) in the Lucid cluster have significant lower spec'ed efficiency and lower peak charge rates than the Lucid
- Does it call into question:
- is the Lucid's efficiency claims, when mapped to real-life freeway speed driving (avg of 66mph on the Taycan, including charging. Probably avg over 75mph-80mph while cruising), is no better than the other EVs?
