Stuck Frunk
That works when the frunk works normally. However when it's stuck, you have to push much harder to get the mechanical latch to close.
I know how it is supposed to work, and have had intermittent frunk latch issue for several months.. I have had several visits to Lucid for service, and have been in contact with their factory service advisors.... I was never told to push harder. -- nor did I ever create body damage to frunk lid as you show..
Yikes that’s frightening. I have another appointment for this on Wednesday. I normally would let it go a little while but I need to refill the washer fluid 😂
I recently suffer front wheel bearing damage from a pot hole. Every part of the front suspension is easily replaceable for good reason. They sacrifice themselves to save the frame. Hitting a curb straight on at 60, I can personally attest.
I won’t even ask how you did this. 🥺
I am still waiting for them to issue the prescribed repair bulletin too... I just don't use frunk at this point.. I have had multiple service visits on this already without a consistent result, but I am assuming that they will have this solved and well sorted at some point, so just being patient
Whatever happened with this? Did Lucid finally find a working fix that held long term? I have seen intermittent frunk opening issues with my GTP as well, but luckily every time it's happened I can just press the haptic button or the fob to try again and it will fire the second time.
They finally fixed mine.. I think it was a very small adjustment with latch and a factory rep finally did trouble shooting.. I think that the Touring and Grand Touring have power open and power close which can be reactivated with second try on fob or hepatic... My Pure AWD does not have this capability.
Same thing happened to me today.
