- Nov 28, 2022
- Edison, NJ
- Kia EV9, future Air?
In addition, is it true that the lucid disables its front motor in smooth(fwd cruising..)? This has not been known before.
I suspect that they do not completely turn it off, rather they detune it to 20 horsepower or a low figure like that. However, my theory is likely to be wrong, as if they could do that, would they not just limit the FRONT motor and also slightly limit the rear motor, for similar efficiency as the FWD but RWD driving manners?I noticed that, too, and it was the first time I'd seen a mention of Lucid's using only one motor during cruising.
I haven't kept up with Tesla's approach lately, but a few years back Tesla went to a permanent magnet motor on one end of the car and an induction motor on the other end of the car so that the induction motor could be turned off for cruising. An induction motor spins freely when no current is supplied to it, while a permanent magnet motor generates drag when no current is supplied. So, if you're only going to use one motor, you would use the permanent magnet motor -- first, because a permanent magnet motor is inherently more efficient than an induction motor; second, cutting current to the permanent magnet motor would create unwanted drag.
Lucid, on the other hand, uses permanent magnet motors at both ends of the car. If you turned off one for more efficient cruising, I assume you would have to disengage it mechanically from the drivetrain rather than just cutting current to it as you could with an induction motor. However, in the 2020 time frame Peter Rawlinson gave some interviews where he said Lucid had developed a permanent magnet motor that behaved like an induction motor, at least when it came to cogging torque (which is a downside of running a permanent magnet motor at low speed). It was not clear whether this induction-like behavior extended to other characteristics of the Lucid motor, although by definition a permanent magnet motor would continue to generate a magnetic field even when no current is supplied to it.
(If I got some of this confused, maybe the engineers here can step in and set things straight.)
Biggest glaring issue between 1&2 vs 3 is Temp (55 vs 105) and tiresAlso, here is a track leaderboard:
It beat EVERYTHING except a GT3(less than 2 seconds behind,) a z06, and it managed to BEAT a tuned cayman gt4 rs on cup 2 tires.
I bow down to the Lucid Sapphire. This is the greatest car I have ever seen. Put proper cup 2 R tires on it, and it would likely beat the z06... And put a proper aero kit on it? I literally CANNOT imagine how fast it would be.
In addition, does the plaid also have one induction motor? I thought with the palladium it is all permanent?
Which set had the higher temperatures, the air or the other 2?Biggest glaring issue between 1&2 vs 3 is Temp (55 vs 105) and tires
Air was 105 and wayyy heavier.Which set had the higher temperatures, the air or the other 2?
I don't know enough about these track cars, so enlighten me a bit about the facts.Also, here is a track leaderboard:
On one hand, higher temperatures means more tire grip(or is that only formula 1)? On the other hand, power is reduced as it needs to be cooled more.Air was 105 and wayyy heavier.
Didn't lucid bring ovee a former executive at Chinese electric car start-up Nio, to lead its business in China? Jiang previously worked for Ford and Jidu Motor, the electric car division of Baid..I think you may be right, but I don't know for sure. Once we had a chance to live with both our Plaid and our Air Dream, I've pretty much lost interest in what Tesla is doing. My brother insists on keeping me sort of up to date on what Tesla is doing on the manufacturing engineering front, which I think is the only area in which Tesla may still be moving ahead of Lucid, at least with the Model Y and the Model 3.
Given that Tesla is producing those cars at vastly larger volumes than Lucid, manufacturing is a much bigger component of the game for Tesla. (Based on our Model S Plaid's fit & finish and the body creaks and groans it's developed, I'm not overly impressed with Tesla's manufacturing and assembly on that model, though.) On the other hand, I have to recognize that, although the Plaid had more issues at delivery two years ago than our Air, it's been in the shop a lot less since than either of our Air Dreams. I attribute this to the fact that our Airs were very early production models and am trusting (hoping?) that later Airs prove their durability over the long haul.
And yes, they are completely stock. The Z06 in particular has beat a Mclaren once, they are regarded as the fastest cars under 300k apart from the GT3 RS. The fact that the lucid is even close to them is astonishing. With the tires they have, it is likely to beat them. In addition, the z06 has the z07 package for aerodynamics, if the lucid had track aero(ugly wings, splitters, etc,) it would DEMOLISH them.I don't know enough about these track cars, so enlighten me a bit about the facts.
Are those first 2 cars (the GT3 and the Z06) in completely stock or modded in some way? Are those the production versions that set those records?
I kind of got that feel, but anyone who knows Savagegoose knows that he is a harsh critic.I really liked the video my one critique it seemed a little too much like Lucid paid for this video. Did anyone else get that vibe? I just never seen so much Lucid involvement in one video. Other than that as a Lucid fan I learned so much about the company, its employees, and how the Sapphire drives. They should do more on Lucid other models.
Sure!And yes, they are completely stock. The Z06 in particular has beat a Mclaren once, they are regarded as the fastest cars under 300k apart from the GT3 RS. The fact that the lucid is even close to them is astonishing. With the tires they have, it is likely to beat them. In addition, the z06 has the z07 package for aerodynamics, if the lucid had track aero(ugly wings, splitters, etc,) it would DEMOLISH them.
I could give more specific facts upon request, I will just send them in DMS to not hijack this thread if you want!
I think it is more about when they get heavy access within the manufacturer, they weight the content in that direction. The best example I recall is the C8 Z06 video.I really liked the video my one critique it seemed a little too much like Lucid paid for this video. Did anyone else get that vibe? I just never seen so much Lucid involvement in one video. Other than that as a Lucid fan I learned so much about the company, its employees, and how the Sapphire drives. They should do more on Lucid other models.
Probably stock, considering it's a review.I don't know enough about these track cars, so enlighten me a bit about the facts.
Fun prediction. I think it will do much better.Sapphire is just a halo car. Though surely it’s the best on the market, if they deliver 500 of them over the lifetime of the program I’d be impressed.
I suspect they will end up reskinning this car and selling it as an Aston Martin.
More grip until the tires get greasy and eventually tear.On one hand, higher temperatures means more tire grip(or is that only formula 1)? On the other hand, power is reduced as it needs to be cooled more.
