Remote Climate adjust
AIR.LUCID
El Dorado Hills, CA
‘04 Prius, ‘98 MB SLK230
Keep comfortable
With the Lucid app, you use Remote Climate to set the temperature in your Air. Whether it’s a cold winter morning or a hot summer afternoon, select your optimal conditions, and your car will adjust before you even open the door.
Does it change the temp. or just the settings? Sorry if this is a stupid question.
Keep comfortable
As you can see from the below screenshot of the app, you can set the temperature:
Now that it's getting quite cold, I'm using remote climate. Is there a way to have it turn on seat heat and heated steering wheel?
Not at the moment, no.
Remove climate seems to be using battery rather than plug in power. Is this the experience with everyone.
