- Jan 3, 2022
- Santa Clara County, CA
- Air GT, XC40 P8 EV
Lucid has mentioned this in the past.Doubtful, Mine hasn’t changed much after a few thousand miles....
Preheating makes a HUGE difference!I think @Westcory did mention his was a 2025. The other very useful tidbit is if the stated efficiency numbers, especially in the winter, are where owners typically preheat/condition their cars while plugged in prior to leaving. This is particularly important to know where short trips are frequent. Although I rarely do that, when I do my efficiency #s are significantly higher. It’s a good habit to get into if you want to achieve higher #s, but I’m just too lazy.
Lots of variables!![]()
Yes, I have noticed today that. I pre-heat while plugged in to the charger. My efficiency was 3.5 m/kw where as earlier it was just 2.5Preheating makes a HUGE difference!
Sorry for my ignorance, but How do you "pre-heat"? Put the battery in pre-conditioning mode? Or turn on heat/defrost?Yes, I have noticed today that. I pre-heat while plugged in to the charger. My efficiency was 3.5 m/kw where as earlier it was just 2.5
AWESOME! Feels good, right!?!Yes, I have noticed today that. I pre-heat while plugged in to the charger. My efficiency was 3.5 m/kw where as earlier it was just 2.5
use the App to warm the interior of the car for 20 minutes or so...Sorry for my ignorance, but How do you "pre-heat"? Put the battery in pre-conditioning mode? Or turn on heat/defrost?
Wow That's awesome! 2025 must have some amazing updates. I'm following your posts to see when you're able to hit EPA rated lifetime efficiency! I'm rooting for you! I think as the temps warm up, you should be able to get there. I believe EPA is about 4.3 miles/kw for 2025 GT?Folks, PLEASE also give your model YEAR as there were important changes to efficiency of the models beginning with the 2025's...
My current "lifetime" (first 700 miles in a '25 AGT -- all winter so far with temps in the 30's) stands at 3.82 mi/kWh. A combination of local and highway. Roughly 60% highway / 40% local.
4.34 to be exact. Remember everyone, the '25 AGT got updated battery chemistry which boosted the pack's capacity by 5.4% (118kWh vs. 112 kWh). I would imagine that they just started using the same pack that the GT-Performance and Sapphire used since those were both 118 kWh packs in the same form factor. So between that, the heat pump and better thermal management folks with '25's definitely should be seeing better range numbers -- all else being equal.Wow That's awesome! 2025 must have some amazing updates. I'm following your posts to see when you're able to hit EPA rated lifetime efficiency! I'm rooting for you! I think as the temps warm up, you should be able to get there. I believe EPA is about 4.3 miles/kw for 2025 GT?
It is certainly better for the battery. Whether there is a net efficiency gain would have to be calculated, but if the humans in the car are more comfortable, the battery in better health AND the operating efficiency of the car on the road is better, I still personally think that it is an EXCELLENt practice.Well, when you preheat at home you are using energy anyway. Not sure I agree with the concept of paying for Kw at home then thinking your car is more efficient. Cold weather is a negative for EVs.
It’s a particularly good practice if you’re headed out on a long drive in the winter, where range may be critical. In that situation you may not care about how many home kWs you used since you want to maximize your battery’s kWs.Well, when you preheat at home you are using energy anyway. Not sure I agree with the concept of paying for Kw at home then thinking your car is more efficient. Cold weather is a negative for EVs.
I mean my habits aren’t any different between all the EVs I have driven and all driven the same roads, climate, and traffic yet the Lucid is the only one missing the EPA rating by ~25%. If I’m constantly getting 285 miles of range out of 405 I’m going to be pretty sad.Doubtful, Mine hasn’t changed much after a few thousand miles. Still have a lifetime average of 3.1 on my Air Touring![]()
yup, unfortunately that’s what you’re going to get. The Lucid is not efficient in daily city driving. Teslas…even the big boys Model S or even Model X is far more efficient just putting around town. (People will disagree with me, but it’s true lol). The Lucid motors are tuned for 65-70mph driving. If you take a long road trip and drive slow like that on cruise control you will see 4.0 miles/kw or better!I mean my habits aren’t any different between all the EVs I have driven and all driven the same roads, climate, and traffic yet the Lucid is the only one missing the EPA rating by ~25%. If I’m constantly getting 285 miles of range out of 405 I’m going to be pretty sad.
I was rally curious if anyone has brought this up to the service department and got any fixes.
I guess you missed my original complaint. I just did a long roadtrip and it couldn’t crack 3.3 in almost perfect conditions. I’m less than 3.0 so far around town.yup, unfortunately that’s what you’re going to get. The Lucid is not efficient in daily city driving. Teslas…even the big boys Model S or even Model X is far more efficient just putting around town. (People will disagree with me, but it’s true lol). The Lucid motors are tuned for 65-70mph driving. If you take a long road trip and drive slow like that on cruise control you will see 4.0 miles/kw or better!
Couple of clarifying questions in that caseI guess you missed my original complaint. I just did a long roadtrip and it couldn’t crack 3.3 in almost perfect conditions. I’m less than 3.0 so far around town.
Please share some data to support this. Otherwise you are correct, we will disagree.Teslas…even the big boys Model S or even Model X is far more efficient just putting around town.
