- Oct 27, 2024
- Hunterdon County, New Jersey
- 25 Air GT/Gravity ord'rd
- GZ3PGK37
Got it! Yes, I would also love to see (from Lucid) a breakdown of how they increased the range of the ‘25’s. What came from battery chemistry change, what came from efficiency gains (and specifically where), etc.Absolutely, no argument there, that’s obvious from any equipment that’s battery driven. All I’m saying is I’d like to isolate the efficiency gain from the heat pump alone. Alone, I don’t think it gives the efficiency increase that some think it does. As I said, this is based on what I recall from previous EVs where a heat pump was later introduced and no other changes were made. OTOH I don’t doubt there is a worthwhile efficiency increase in the 25 Lucids when all the improvements are summed up. Again, I’m just curious about the heat pump’s contribution.
As for pre-heating the cabin while plugged in to gain efficiency, again no argument. I’ve done that with a variety of my previous and current EVs and saw a significant gain in initial efficiency at the beginning of the drive where efficiency is typically at its worst.
I am certain that there IS a gain in efficiency between the heat pump and resistive heat…and probably a fairly large one, actually. This is an absurd comparison, but have you ever looked at the difference in energy use of an 85 gallon traditional electric hot water heater and an 85 gallon heat pump hot water heater? It’s insane…
