- Feb 13, 2022
- Scottsdale, AZ
- GT
- IDLI9CO7
Thank you.OK. Two of the pages were hacked from earlier owners that developed a good checklist and can be found on earlier threads (Pricing and delivery threads). I have added a few extra:
1. Provide wheel alignment printout. All wheel alignment machines do this, so I want to have evidence that it was done and is within spec.
2. Inspect wheel balancing weights to ensure that no more than 3 oz of stick-on weights on either inboard or outboard are exceeded. If exceeded, then they need to remount the tire on the wheel to minimize the balancing weights (procedure called match mounting). If they can't do it then, then that calls for a new tire or wheel, or both.
3. Check AC temp in vents with thermal probe (on Amazon for $10) Temp should be between 40 and 45 deg. F steady state both front and back vents.
4. Monroney sticker should be in car
5. Turn signals are operational
6. Hardcopy of Owner's Manual and screen cleaning cloth are in Glovebox.
7. Test the 12V batteries and the HV battery are able to be fully charged and the charging function is fully operational. I plan on using a battery tester for the 12V. Batteries. if these 12V batteries have been sitting around for weeks waiting to get installed in an un-air-conditioned space (75 deg. is optimal) in AZ in the summer, then their charging capacity has already been compromised.
8. Rear and side mirrors fully adjustable and side mirrors fold in and out.
9. Check for squeaks in the seats, doors, steering wheel, windows, instrument panels and other locations.
10. Check to ensure all exterior lighting is functional (headlights, taillights, brake lights. turning signals, etc.)
11. Check battery and engine coolant lines for leaks and for proper connections and support (no interference with drive axle and suspension) Recall Item.
12.Check fluid levels inside maintenance panel in frunk
I have told them that any safety and security related issues not working (Brakes, lights, startup/ shut down, cracked windshield or windows, opening and closing doors, etc will be a game breaker and to go try again. I know this an extensive list, but I want to avoid multiple trips back and forth from the service centers and thus be without use of the car. Hope they can get it right the first time, for all of us.
That's about it. I don't think that's too much to ask of a car selling for $140,000, do you? I don't.
I‘ve never done #1 and 2. Have folks been able to obtain the printout.? I suppose we have to ask in advance of delivery.
