- Apr 17, 2022
- Chula Vista CA
- Tesla MX, Air GT
It has been confirmed, though, that ZERO Teslas have received .43 as of today.
Good one!
Hi, @idiot900. Would you mind DMing me your VIN?I just got my fourth 2.1.47 update notification. Assuming this represents a kink to be worked out of their new update mechanism. I suspect with each update the car only ends up verifying that it is on the latest software, which is why the same update is faster after the first run...so I'll hold tight until we have word from Customer Care (surely someone has contacted them by now) or @mcr16.
Not sure how Bobby can help you, but maybe @mcr16 will need it if a 3rd notification pops up.Here I was feeling left out with only one successful update and no further notifications…until just now. Second update notification received. Bobby, sending VIN.
Or shortly after. TPMS gives rough numbers that may out may not be accurate, depending on its mood. The TPMS is just an under inflation warning device. The OPs tires are dangerously low.You need to be driving in order to check tire pressure and then it will show up on your app.
me tooSeat and steering wheel heating, and seat ventilation, have definitely turned on automatically based on HVAC settings for me.
OMG, now THAT is amazing. heading out to check now, it's 32 out.me too
Same here - I’m on at least 3, maybe even 4 notifications to install.I just got my fourth 2.1.47 update notification. Assuming this represents a kink to be worked out of their new update mechanism. I suspect with each update the car only ends up verifying that it is on the latest software, which is why the same update is faster after the first run...so I'll hold tight until we have word from Customer Care (surely someone has contacted them by now) or @mcr16.
yes.So -- has anyone in this forum successfully performed an EA P&C session after 2.1.47 update?
Welp, thanks for the reply. It would appear to be unrelated.yes.
Does it fail and not even give you the payment screen on the station?Welp, thanks for the reply. It would appear to be unrelated.
Still wondering why my P&C is failing. I'll try again tomorrow at a different site.
Sent you the info.Hi, @Deathlyshiv. Thank you for sharing. I have sent you a DM.
Is there is anyone else experiencing the same issue, please shoot me a DM with your VIN.
