It will flash white, then it turns green but solid green, not flashing green which would mean it’s actually charging. Solid green I guess means the car stopped charging.Are you saying that when you first plug it in, you see the white light. Then, without doing anything, the green charging light starts up?
Thanks. Another question for you. Have you noticed your seat and steering wheel heater going on when you first go in car without you turning it on?It will flash white, then it turns green but solid green, not flashing green which would mean it’s actually charging. Solid green I guess means the car stopped charging.
I think this is an option you can toggle off. When the option is on, it anticipates based on temperature that you want seat and steering wheel heaters on. I am pretty sure I turned it off but it was a while ago so I am not positive and don't remember where I did it.Thanks. Another question for you. Have you noticed your seat and steering wheel heater going on when you first go in car without you turning it on?
Correct. I do not recall the setting location but I turned it off shortly after delivery. Might turn it on as the weather has gotten cold.I think this is an option you can toggle off. When the option is on, it anticipates based on temperature that you want seat and steering wheel heaters on. I am pretty sure I turned it off but it was a while ago so I am not positive and don't remember where I did it.
Here is the setting:Correct. I do not recall the setting location but I turned it off shortly after delivery. Might turn it on as the weather has gotten cold.
We'll get you to the next one!I’m so bummed I missed this event. Wasn’t even aware it was happening.![]()
