- Oct 3, 2025
- Gravity GT,Tesla Model S
- Air DE Number
- 2
I also had a similar problem when I was playing and testing. People who used a Teslatap adapter seemed to be successful. I called the teslatap company and they told me that the Teslas tap #2 dip switch in the up or on position will require that you install the Teslastap 30 seconds prior to connecting to the gravity adapter that comes with the gravity. The Teslataphas a small circuit that helps with communication and success on the gravity. The Teslatap person was not correct with several of their suggestions. If you are charging at 48 amps you can purchase a less costly Teslatap. I bought the more costly lightening version with hopes of 80 amp charging. That failed for me.I have the Gen-2 Wall Connectors set to 48A. I plug the Tesla NACS plug directly into the Gravity. The car says Cable Connected immediately and Charging starts soon thereafter. I have left dip Switch #2 to Normal (UP). Putting switch #2 to Legacy has not worked for me.
I still charge Teslas, and this is part of a shared 3 Wall Connector setup. The charger that I am changing settings on is the Master Charger that communicates with the other chargers to set their respective current, which maxes out at 48A.
I had trouble free success at 48 amps gen 2 plugged into Teslatap adapter which makes the connector a J-1772 so I used the adapter that came with the Gravity to plug into to convert back to the nacs plug for the gravity.
There is definitely a communications issue that the teslatap helps with. I have heard that there is a timing issue once the adapter is plugged into the Tesla gen 2 charger with the #2 in the on position.
For me the I leave the teslatap connected to the Gravity J-1772 to NACS adapter and just plug the gen 2 charger into the teslatap. You should wait 25-30 seconds then plug into the Gravity. That should work but unfortunately the Tesla Tap in not inexpensive.
Good luck
