New Unnecessary Chime
peacenow0
Los Angeles
Gold Lucid Air DE
DE Number
195
With the last update they added a chime that goes off EVERY time I exceed the speed limit — which feels like a hundred times a day, based on the number of times it’s gone off and annoyed me. Are you kidding me? Who doesn’t drive above the speed limit by a few notches?… 3-5 MPH (at least, depending). I can’t help but wonder why they created this in the software instead of something customers are waiting for.
That’s been there a long time. It’s a setting. You can set it to “visual and audio” or just “visual”
What if I just want to turn it off completely. Last thing I need is for my wife to see a speed limit sign turning red!! (let alone chiming)
Secrets don’t make friends. :p
No, I don’t think you can turn it off presently.
What’s it under in settings?
To configure Speed Limit Alert settings, use the Pilot Panel and touch > DreamDrive.
Touch to enable or disable Speed Limit Alert. Additional options to receive VISUAL or VISUAL AND AUDIO alerts are available when this feature is enabled.
Touch to enable or disable Cruise Speed Update. When enabled, this feature notifies you when a new speed limit is detected and prompts you with an option to update your cruising speed when Adaptive Cruise Control is active. It is the driver's responsibility to determine the appropriate speed limit, road conditions, and driving speed. See Adopting new speed limits.
NOTE: When this feature is disabled, the detected speed limit will still be displayed next to the set cruise speed on the Cockpit Panel.
