Lucid Gravity UX 3.6 is here!
As soon as it calibrates and DD becomes available the menus will show up.
How did you come to this conclusion? Did you have the same issue and after the calibration, the menu items showed up?
After the update, I lost the “key fob” tab within software update in the app. Anyone else have this issue?
My Key Fob tab is still visible in the phone app (android).
Think that's an iPhone app bug. Try putting your finger around the Version no and drag down slightly.
Had something similar that I can't seem to reproduce on the main screen when pressing the little down arrow to get the additional icon buttons. That worked but afterwords the screen wouldn't scroll and the up button was missing. Had to quit the app and restart.
Thanks for posting this. I thought I was the only one with this problem and I have DreamDrive 2 Pro. I called customer care and they have opened a case.
Did you try the calibration procedure and if so, did the missing menu items appear?
No, I haven't driven it yet since the update only finished yesterday evening, but I'm planning to take it out today.
I don't know if this is the handy work of @marqie but, I received the push around 7pm tonight. Either way, thank you so much Marqie! It may have taken about 2hr 30 mins to install. I know the instructions say to calibrate on the highway during the day, but I couldn't help myself and went for a drive around 10:20pm. About 2 mins into a highway driving, the "feature unavailable" went away for the drive assist.
I turned it on and the drive itself was flawless, except for the fact that the automatic lane assist does not work.
And when I engage the turn stalk to change lanes, the Automatic Lane Assist immediately says "feature unavailable."
I parked somewhere to do a soft reset with the hope that it would clear on my drive back home, but the automation still isn't working. But manual lane change worked 2 of the 5 times that I tried it.
Anyone else having this issue, and if yes, any solution?
Perhaps I need to drive the car again but during the day?
Update: I went for another drive this morning and it seems that the issue is gone. Lane changes are really great and the car itself is well centered, unlike before where I think it gets too close to the right side marker.
The adaptive lighting is a busy bee for sure, very active. Loving it so far! I never had any issue with the fob to begin with (April 2026 GGT purchase) but it is even much better now as well.
Great job, Lucid!
Still waiting for the update 🤨
I just tested my frunk which used to take two tries to open. It's opening on the first try now. I read that was something 3.6.0 seemed to have fixed too. Notch EV mentioned this too.
I'm pretty sure they changed something there. I think it takes a bit more time before it starts lifting the hood.
Yeah. Had one of their service techs say the problem was the timing between the lock and the frunk lifting was causing the problem for some. I can see and hear it taking just a hair longer to lift.
Rats, that's disappointing as it doesn't seem like it would have been too difficult to add, and since the fobs are such a huge issue for so many that I hoped it would be a priority.
I can hear the mirrors and handles in my quiet garage (where it doesn't really matter if it locks... in fact I'd rather it didn't there), but outside in a busy parking lot off a busy street (where it matters) is another matter, especially when it was so slow to finally lock. I'm often 3-4 car lengths away still craning my neck and can't hear it by then amongst the background noise.
Anxious to see if it's really gonna respond in a timely manner now. Encouraging that it has for you but the fobs have been so different for so many people that I don't wanna get my hopes up until I actually see it.
There is a way to make noise when you lock it. Before walking away, open and close the Frunk or Trunk, but when you hit the close button RUN away so that the Key Fob loses connection before the Frunk/Trunk closes. It baffles me why they included a honk for that case but not for normal locking.
Yes. After the update and before moving the car I started browsing the settings. I was specifically looking for the 'Conservative/Assertive' setting and did not see it. I pulled out of the garage and started driving. After several minutes DD Pro became available but I didn't do anything with it. I did not check settings again until I stopped at my destination and the 'Conservative/Assertive' options were now there.
The release notes recommended a full sleep (power off and restart) after installing. Did you do that?
Either way, that should fix this issue. If it keeps happening, there is likely something wrong with your cameras and you should schedule service.
