Lucid Air Stereo "Surreal Sound" Test Impressions
Status
Not open for further replies.
Color me old-fashioned and possibly even wrong, but I'm of the belief that streaming in a car can't be as good as a sonically well produced CD in a decent home system.
Keep in mind also, you could be sitting at a charger for 20-30 minutes. No road or engine noise there. Someone would have to chime in if there are loud cooling fans that can be heard inside the car.
Its time for the charge stop playlists!!!
Keep in mind also, you could be sitting at a charger for 20-30 minutes. No road noise there. Someone would have to chime in if there are loud cooling fans that can be heard inside the car.
Yes there are
There’s something to this, as the vast majority of streaming formats are inferior to 16bit 44.1khz audio you get on a CD, because during the CD era that’s the original format most songs were recorded and mixed in if it was a digital recording/mix. Nowadays everyone does 24bit 96khz so you’re missing even more, using regular quality streaming services really limits what you’re experiencing. I’ve had the good fortune of being able to do A/B comparisons of 24bit/96khz material with various streaming versions including FLAC format in a professional film mixing studio and the difference is very apparent. Sample rate (96khz vs 44.1khz) is less critical than bit depth but you can still hear a difference particularly in quieter parts. For loud tracks that slam the limiters/compressors it doesn’t matter because all bits are being occupied by the data, but if there’s any quieter moments in the track you will literally miss entire notes or entire instruments in regular quality Spotify. I should qualify this by pointing out that obviously most people could care less, they just want to hear the lyrics, but once you do hear the difference you can’t “unhear” the deficits in various streaming compression formats.
Like loud intrusive?
Not as loud as it is on the outside? I don't think it's intrusive, but that might be because subconsciously I KNOW that the fan has to run?
Very well put. A good example of this imho is Golden Cage by The Whitest Boy Alive. Play it on a CD or Apple Music vs. Spotify - you can hear Marcin Öz (bass) moving his fingers across the strings in the quiet moments when you've got a good quality source.
Okay even using Spotify in the car with my untrained ears this track sounded amazing. Not even on HiFi...!!!
Lol. Glad you like :D
Here's another, don't know about repeat play, full chill though.
Got this about a year before I ever heard about Lucid Motors
Anyone know if devices that aren't phones are able to pair yet?
I’ve been able to pair iPads and MacBooks. So far have not tried any HiFi dac or other devices.
Among my many hobbies is DIY HiFi. I build speakers and amps for fun and have a passion for really great sounding systems. There's a special kind of joy from listening to music on a system you designed yourself and is really dialed-in for the room. You get to realize the fruits of your hard work in a way that few other hobbies provide.
Ever since Lucid started marketing the Surreal Sound, I knew I had to get a proper test. With that in mind, I met up today with @borski to run some tests on the stereo using a measurement mic and a few reference tracks.
TL;DR: Excellent sound staging if a little bright on the treble, small drop around 130-200hz, great bass extension but needs some oomph. You'll probably want to bump the bass EQ +2 to +4 DB and the treble down -1 to -2 db (if it seems harsh at times, YMMV). Designed for long-listening without fatigue and brings out details you'll love to hear.
The Data
Below is the results of some test loops between 30hz-20khz. I used Room EQ Wizard on my laptop, connected to the Air via bluetooth.
Caveats:
  • We ran this with both of us in the car, climate control off, but there's some reflections and background noise that make the graph rougher than it will really sound to your ears.
  • I was in the passenger seat which is going to have a disadvantage vs. driver for my impressions of music.
  • I intentionally did not test Atmos tracks. The goal here was pure 2ch stereo as that is what I know and can test the best.
  • [edit] Apparently, to connect a laptop to bluetooth you'll need to have it set up both as a phone and audio device in the Air.
Technical Impressions
  • Bass goes a long ways down, but has a -3db of 44hz before it levels off and then stays solid to ~26hz. This means a few of the deeper bass hits lack "oomph" but are not by any means missed.
    • This is something that could be adjusted for in EQ and I'm surprised they let it remain. I would have dropped the mid bass down ~5db and bumped up the absolute bottom to compensate.
    • The sub clearly rolls in at 150hz and has a lot of output. However, it isn't booming which means some tracks can feel light because we're used to overcompensated low-end in car stereos. This means you get a more "real" sound, but can lack a bit of excitement unless you crank it.
  • There's a dip after the sub where the mids roll in, rising to a pretty big hump at 700hz before rolling back as you go higher.
    • The midrange is very healthy. Music might seem more "full" than you're used to - that is how it should sound!
    • Lots of car stereos will lack output in several spots of 200hz-2khz range, resulting in entire instruments going missing on tracks (either due to DSP, reflection/cancellation, etc.) The lucid does not have this problem, despite the jagged response due to room modes.
    • The dip on the lucid at 130-200hz isn't that big of a deal as you won't notice it, except with very cello-forward or string-bass compositions.
  • The treble is a bit bright and could cause a bit of fatigue on long sessions.
    • That peak at 8khz is pretty noticeable, and some tracks might end up harsh.
    • The treble ends abruptly at ~16khz for some reason. This is probably the DSP as it definitely doesn't look like a natural rolloff on the tweeter. Since I was running pure 2ch output this could be Atmos' fault. It won't mess up your listening.
Impressions with Music
I was very happy with the sound staging and depth of response. Horns, strings, vocals, all excelled. We tested Ce Matin-là by Air for purity of a French horn, then Loyal by Odesza for a more complex arrangement. Both did extremely well with the instruments being very clearly placed with no "fuzz". We also gave Young by Vallis Alps a go for a slower-paced but dynamic track with my favorite combination of vocals and bass of late. The singer's voice was very clear, no ringing or harshness (very hard in a car) and the bass line was tight and didn't suffer from any phase delay or lingering-boom. I should have popped on some Faith No More to get a feel for kick drums. Oh well, next time!
We also tossed on some good orchestral and Jazz tracks (Snarky puppy!). The midrange is really a highlight on this stereo, with every instrument coming alive. The guitar, cello and flute on Morning in Norkia from the anime Last Exile (random track, but absolutely excellent engineering) sounded like they're right in front of you. For fans of live instruments and vocals you'll be very happy. Synths and electronic music also do very well, with swelling sounds getting goosebumps immediately.
However, the system can also be unforgiving. You're going to notice poorly engineered tracks much more readily as you can hear the difference in quality between the live instrument and the synthesized one. Sampled music with hiss/hum or low quality takes will be clear as day. This is common in HiFi, but hearing it in a car is a first. It will bring out imperfections in ways that surprise you, an inadvertent drawback for the level of detail it provides.
That said, the overall experience is really joyful. There were moments that the music just really took over and the world melted away. I've not gotten that in a car before the Lucid!
Areas for Improvement
The system lacks volume in the absolute lowest octaves and getting that bottom end to really hit. This could be compensated with EQ, but I didn't have time test what range the bass EQ will affect (some of them go all the way up to 300-400hz). It doesn't lack for extension, just output, and I don't believe it is from insufficient amplification. A feature I'd love to see from Lucid is the ability to more finely tune the response, or at least some improvement in percussion and sustained bass notes while dialing back the top. An optional 10-band or better EQ would be a nice option for advanced users.
The top end can be a bit bright, especially with cymbal-heavy percussion, but I didn't detect a lot of distortion. Dialing this back a bit to reduce fatigue would help. I don't know what drivers are used, but this is common in titanium and aluminum dome tweeters that can get really tinny without some proper adjustment. I'm wondering if the glass canopy causes a lot of reflections or cancellations, which means they have to boost output to compensate. I've not designed a car stereo however, so I'm sure they've got their reasons why they bumped up the top-end.
(Note on treble: as you age your hearing in the higher range can diminish, which may make you want more treble to compensate. This is completely normal so take the top-end feedback with a grain of salt.)
Fix that extreme low-end: I'm not sure if there are two subs instead of one, but a -3bd of 44hz is pretty high for what the car has. Maybe a shelf biquad with a high Q to raise it a few db?
Final Thoughts
This is absolutely an excellent system. The level of detail in it is top-notch for a car stereo and with a little bit of adjustment you'll get a ton of enjoyment. I'd say this is designed more for extended listening without fatigue instead of thumping along. The end result is you'll find yourself listening to music longer without needing to turn it down, and will notice things that had been missing. It will capture your interest in a way most car stereos do not, akin to sitting in a dedicated listening room with a dialed-in system.
A lot of mass-market car stereos will hit the bass on a track hard. They'll get your blood going, but you also end up turning it down after a bit - there's distortion, ringing, or a "boom" that fatigues you. The Lucid does not suffer from this at all. Instead, it feels like a system that could use a few improvements, but gets so close to the mark that I really can't fault it, which says a lot.
I'm really surprised to get a stereo this good on the first car from a new carmaker. Surreal sound indeed!
I am still going with my current Morel setup…Do you think a Morel MW9 would fit In the front if I get some fabricated kickpanels? Or do I have to size down to the MW6?
I would size down. To fit the MW9 will require moving the window switches or having the kicker at a very significant angle.
No no bro…not in the door…By the kickpanels by the floor board…see arrows in the image.
A fellow car audiophile…That trunk space looks very tight…What do you think about going with 2 Acoustic SBP 15s or 2 twelves in a trunk baffle setup? Vs trying to fit 2 12s in the empty storage compartment?
So you checked the out the car…What are your thoughts about me fitting 2 subs in a trunk baffle setup?
I’ll do some measurements tomorrow.
Appreciate the help. For the trunk baffle the subs would definitely be Acoustic Elegance SBP 12s or 15s…….For the storage maybe 2 12s. Not sure what subs for that setup.
This car needs a sub?
Status
