Not disagreeing, but be aware that you can unlock your car with a dead fob if you need to. Hold it next to the camera on the B pillar and it will work just like the key card, allowing you to unlock, and after entering your pin on the pilot panel, drive.Why cant Lucid have an interface that tells you how much battery is left in your key fob? It is so frustrating not knowing and being concerned it may run out when I am at a location.
There's a video of this process in the FAQs of www.lucidupdates.com.Not disagreeing, but be aware that you can unlock your car with a dead fob if you need to. Hold it next to the camera on the B pillar and it will work just like the key card, allowing you to unlock, and after entering your pin on the pilot panel, drive.
Several years ago, I would get a message that the key fob battery was low (in the Lucid Pilot Panel). I believe after the last key fob software update, I no longer got any messages - but then again, I stopped using the fob because the phone key was pretty reliable, so can’t say if this message is still there.Why cant Lucid have an interface that tells you how much battery is left in your key fob? It is so frustrating not knowing and being concerned it may run out when I am at a location.
#FobSchmobSeveral years ago, I would get a message that the key fob battery was low (in the Lucid Pilot Panel). I believe after the last key fob software update, I no longer got any messages - but then again, I stopped using the fob because the phone key was pretty reliable, so can’t say if this message is still there.
They removed it for a while but it’s back now.Several years ago, I would get a message that the key fob battery was low (in the Lucid Pilot Panel). I believe after the last key fob software update, I no longer got any messages - but then again, I stopped using the fob because the phone key was pretty reliable, so can’t say if this message is still there.
Where in the pilot panel? Does it show fob battery level only when low or at all levels?They removed it for a while but it’s back now.
It gives a warning on the left side of the center dashboard where it normally says “Smooth” and your trip odometer.Where in the pilot panel? Does it show fob battery level only when low or at all levels?
Oh so the cockpit panel?It gives a warning on the left side of the center dashboard where it normally says “Smooth” and your trip odometer.
Yes, left side. I sometimes incorrectly refer to it as the dashboard.Oh so the cockpit panel?
Dashboard actually works too.Yes, left side. I sometimes incorrectly refer to it as the dashboard.
I wish we could wirelessly charge the fob, like you do with a watch or hearing aids.Why cant Lucid have an interface that tells you how much battery is left in your key fob? It is so frustrating not knowing and being concerned it may run out when I am at a location.
A few notes:My fob isn't in range of the car most of the time, just when I'm in it. And I prefer using the fob to the mobile key, it wasn't working that well for me. I'll see how long the new battery lasts.
