Both Gravities had 3.3.5 downloaded last week.
3.3.5 does not fix the keyfob issues alone, without the keyfob update from the SC.
And with the car already powered up, why would a failure to recognize the key fob shut everything down? We've had failures to recognize before in both cars, causing it not to go into gear, but nothing like this ever happened.
I don't know. It was a guess. I have no data and was simply surmising, because the symptoms otherwise make sense. If it thought there was no key, and that the car was uninhabited (the weight sensor didn't go off, you hadn't fully sat down, who knows), all the other symptoms flow from it.
Not always easy to do when not at home or with other people in tow.
Totally agreed. Wasn't suggesting you shouldn't
had to. Just suggesting it might have fixed it.
Consider all the things that happened more or less simultaneously:
- screens going black
If you're not in the car (or the car thinks you're not) and/or have no key, they'd do that.
- doors not opening electronically but windows still working
If you're not in the car (or the car thinks you're not) and/or have no key; they can do that. You can remotely open them too from the app.
- then windows subsequently freezing
This was either a seal issue (if it's still happening), or something weird, but my guess is seal.
- horn blasting when you exit the car
- first ever occurrence of window failing to stay closed.
Seal issue above. The symptom, if you can repeat it, if it is the seals, is: you try to close an open window, and it goes up, then comes back down to about halfway. It will do that three times, and on the third (or fourth, I can't remember) time, it will not go up automatically, but you can hold the button to go up and it will close. Alternately, if you open the door it will close on the first time.
If that isn't the case, my guess is wrong.
Frankly, I no longer give a shit what causes what and what workarounds cure what. I don't care if it's hardware. I don't care if it's software. I don't care if it's because our car is a one-off lemon (or a two-off in our current case). I'm just sick and tired of these Gravities throwing curve ball after curve ball at me as the Air did for the first ten months. As a habitual automotive early adopter I've had a few experiences close to this with one car from a brand, and I've cultivated a lot of patience. But I've never seen this with three cars.
That's a separate issue. I'm curious what went wrong. I'm not suggesting knowing what went wrong should make you feel better about your experiences, just because it satisfies my curiosity.
I've noticed something interesting on the forum for some time now. When I began reporting the issues with our first Gravity, there were several posters who said more or less, "hey, sorry, but my Gravity is just fine, functioning perfectly . . . ." Yet in looking over their other posts I have found either things to the effect of "well, I did have that problem" or "mine is beginning to do this, too", or "I have found that if you do x (reboot, remove and reinsert the fob battery while holding some button, put one seat x inches ahead of the other, get away from the car and cool your heels while the car goes through a sleep cycle, let the window up and down three times and then open to door while pressing the window, forgo this or that feature, pat your head while dancing on your left foot and spinning three times, etc.), the problem will go away."
I've had three issues:
1. Key fob unrecognized, which the battery reset fixes; since 3.3.2, this has exclusively been errant error messages but no inability to go into gear, and no need to reset the fob at all (for us). An errant 'key fob not found' message without any actual 'getting in my way' does not bother me, and will be fixed, so meh.
2. My second row squeaked, so I moved the seat and it stopped squeaking; it's on an eventual due bill.
3. The black screen issues happened, but only when you got in the car and waited 20-60 seconds. This was the 'fresh boot' thing, and it happened once every few days for a few weeks, but only at the outset. Once the car booted, no issues. And it hasn't happened in a long time.
That's it. So you're right; not
technically flawless, but
effectively flawless.
I suspect there are more like mine than there are like yours, but I don't have the numbers.
And
even if that's true, I am still sad there are
any like yours, and that that number is higher than I wish it were, even if it ends up being small (if we ever know).
