Gravity Bugs / Issues
I was curious, so I searched for instances of "not acceptable" on this forum. There were only 200 matches. I thought there would be more.
EDIT: there were also only 200 matches for "Lucid should", so I guess the search function returns a maximum of just 200 results.
Apple Digital Key support for Gravity is said to be Coming Soon (hopefully we won't have to wait until Thursday). So theoretically, those who carry an iPhone with them will have a more seamless key experience that doesn't require fiddling with a keyfob. It's still a good idea to always carry a backup key card.
The issues I'm having so far:
- Spotify worked on the first day but is no longer working.
- Wireless charging doesn't seem to be working. I keep getting a notification that it's not available and I need to contact service.
- Phone calls don't work too well with car's bluetooth. People complain that it's really hard to hear me. When I put my phone on speaker, there's no issue.
Does anyone know how to do a system reset?
If you reboot the car with the steering wheel method, everything should work again.
What’s the steering wheel method?
Wireless charging not working, see service error on screen (yes, wireless charging is not working).
This is likely your case. Remove it and see if it works. I have found that my old MagSafe case didn’t, but my new one does.
alright, gonna remove the case and give it a go. thx.
-iThinkEV-
-iThinkEV-
Let me know! We did have the issue come up a couple times, but it went away after we removed the case.
Here, have another giraffe or two :)
My list....
HUD reflection.
Key fob not detected like everybody else, but yes, jiggle usually works.
The sensor issue, but have no PPF yet. A soft reboot fixed (but if persist if I don't reboot, happened twice).
Side video disappear from cockpit screen when using turn signals (until next drive).
Rear view video not working one time.
Couldn't got into Reverse 1 time, this also happened at the same time that said sensors not working, so not sure if they're related. Soft reboot fixed.
Charge port was locked and couldn't pull charger plug out. lock/unlock from fob didn't work, pressing button on charge port didn't work. numbers lock/unlock from cockpit screen finally worked.
-iThinkEV-
At least they are consistent with repeating Air issues on the Gravity.
Update:
After doing a soft reset, the music streaming apps (Spotify, Tidal, etc.) come back but then disappear again the next time I drive. I tried this multiple times. Microphone and charging issues also persist, though I was not expecting a soft reset to fix those. I have a service appointment in a couple of weeks to address this.
Update:
You can also do a profile switch to guest or someone else then switch it back and the music apps will show back up.
A related question: is the profile switch quicker than in the Air? When we rented an Air, switching back and forth was a pain.
Way quicker!
It's pretty quick... maybe 10-15 seconds then you type in your password.
I can also confirm that it fixes the music app issues (as does a steering wheel reboot).
Personally, I am just glad there are starting to be enough Gravities (Gravitys?) out there so we can start to hear about what's working an what isn't. It's been a painfully slow launch. How am I supposed to pick up an off-lease Gravity in three years after my Air is done if you all don't take delivery in the near future?
I have the same idea :)
The left rear window stopped working today, as well as all of my cameras. Tried a hard reset, but nothing yet has worked. Service is on it already though, so hopefully they can get a solution.
