Gravity Bugs / Issues
Did a software update last night to 3.3.2, and now I have no radio or turn signal sound. I changed the radio channel and turned the volume up and down, but no sound.
Have you reset the vehicle?
Random bug.
I was parking for the first time in my new gravity. Sensors worked great. But after parking, the sensor ping kept going and going. Didn’t stop until we got out and locked the car.
Posted in a separate thread but adding here for good measure that my front passenger door electronics don’t work, so window doesn’t go down to get in frame, electronic release doesn’t work and window button doesn’t work. Somehow missed this at delivery.
So does this mean your front passenger door won’t open? If window won’t go down, door can’t open.
Had similar issue on my driver side second row. It was the window regulator that needed to be replaced. If you can’t operate it from driver door buttons either, that could be the culprit.
That’s right, door doesn’t open except from inside but it isn’t adjusting the window which means it’s hurting the seal if you use it.
I saw your previous post (thanks for those!) and it sounds like I may have similar problem. Super frustrating and wish I could it at delivery.
FWIW they told me not to open the door at all when window was up and it wasn’t working. Hence my “well, then it’s a safety issue” cry to Lucid who, to their credit, then moved quickly to address.
Yeah clearly I shouldn’t, however I definitely have a few times while trying to be smart and fix it. It shall now not be touched.
I also just got 3.3.2 (it delivered yesterday with 3.3.1).
When I did delivery and I asked about PaaK and the guy thought before end of the year.
Not sure if you can call it a bug but Im having the the Gravity ceramic coated today. When I went out this morning I discovered a piece of trim had gone missing last night. Called service to have the issue added to my ticket for October 13th. Hopefully they can get the piece in before then,
Totally normal. Costs extra for the piece with platinum to be snapped in and glued on. Silly you! 🤣
I've had this happen before the update. It goes away by next drive. A reset might clear it immediately, but by next drive, it should be cleared. Had this happen twice in the two/three months of ownership, so it's rare.
Random bug.
Sorry for your troubles, that sucks. I appreciate you mentioning this problem as I’m adding it to my delivery checklist to make sure window controls work for all doors and the driver, and windows actually seal.
Not sure which "random errors" 3.3.2 is supposed to fix but I'm still getting "Headlight Error" and "DremDrive Pro" error after the update. Also getting the occasional "Key not Found" error while driving. In addition, while driving back from Carmel to San Diego yesterday (about 450 miles) the DreamDrive Pro tried to turn off of an exit on its own on two different occasions. I don't think this vehicle is ready for "hands free" driving yet. I will say it was my first experience using the Tesla supercharger network and it worked flawlessly.
so after 3.3.2 I have a few new issues.
1) Turn signal cameras are lagging when coming up. Takes about 1 second for the video to load
2) User profiles are only loading part of the user profile, either seats or steering wheel about 50% of the time
Try a sleep. I had this issue come up on one drive, before this update. A reboot or sleep fixed it (can’t recall which) and it hasn’t come back
After the 3.3.2 update, I've noticed a few more times (though this is admittedly more anecdotal, not enough data points to draw a conclusion either way) where jumping into the car would boot the driving systems, then the camera systems (they take ~10s to boot up, so usually by the time I'm ready to reverse out of the garage which is nice), then the infotainment systems on the landscape screen + right side of the driver screen after about ~30s. The HUD also seems to sometimes come on between the cameras and the infotainment, but I've had it 1× or 2× when it wouldn't turn on at all till I park and toggle the HUD off and on.
More annoying than critical, at least for now. Probably the most annoying part is that the infotainment systems seem to also control the seat position and profile, so I have to manually scoot forward to counteract the auto-egress shift backwards.
I took my GGT delivery yesterday. I am able to connect my phone to the car via Bluetooth but I don't get any volume when I play something. Same with calls. I tried to connect my wife's phone. Same issue. Am I missing something simple here?
are you choosing bluetooth as the audio source?
This may sound obvious, but make sure you're selecting "Bluetooth" as the audio source. Early in my ownership, I was testing the use of Google Maps on my phone, but having the directions play through the car audio. Didn't hear anything until I selected "Bluetooth" even though my phone was connected via Bluetooth.
Also stating the obvious because this happened to me when I set it up the other day- make sure that whatever music app you're using on your phone has the volume > 0 too. The car's volume setting is relative to the source's setting.
