Gravity 75 mph Range
If the GGT with the 450 mile config actually delivers a 75 mph range test that has Lucid's indicated 20% reduction, that'll be 360 miles. I'll be happy with that, although of course I won't complain if the Gravity does better.
I forgot to mention that the article likely tested an early Air GT which received its EPA numbers under a more favorable testing regime. 2025 and later Lucid cars use a more stringent EPA testing method and so achieve a higher percentage of their EPA rating at highway speeds.
The AGT's claimed EPA range was/is 512 miles and its battery size hasn't changed much either, correct? Thus, independent of the EPA test criteria, why would the conclusions be different?
The 2025 AGT has a larger battery, and some efficiency improvements, and has better actual range than 2024 years and earlier. As the more stringent EPA test method used for 2025 and later cars results in a lower overall reported EPA range for a given vehicle, at freeway speeds the 2025 AGT achieves a larger percentage of its EPA range than 2024 and earlier cars. The topic was exactly this, EPA range vs real world range.
Perhaps the 2025 AGT might fare better. Did Lucid actually changed the claimed EPA range or the mi/kWh on the 2025 AGT?
Yes.
Yes.
I am NOT talking about wether there was improvement on efficiency on the 2025 AGT. My question is, w As you pointewd here is the data (not ancedote) that quantified the actual achievable range on the 2025 AGT vs competition.
As you pointed out in your posting, as a group, the German EVs often meet/exceed their claimed efficiency and range. In contrast, Lucid andTesla aoften missed their EPA ratings in real-life driving. Most readers in this forum report averages of ~3.6mi/kwh . Yes, some report higher in certain circumstances. Mosst owners tend to agree that if you are on a roadtrip (say 75mph), the realizable range is between 70-80% of the EPA rated range. The 10% OoS race is another contrast. The Taycan , with inferior claimed efficiency and range, handily beat the AGT.. in the 10% challenge, the AGT didn't lose because it "mis-calculated" and ran out of cahrge. It ran out of charge in upstate NY, less than 10% distance to the finish line. And the AGT was in 4th place, behind the Taycan, Hyundai, and the Tesla (model 3, I think). It is hard to argue with real data.
