- Jan 3, 2022
- Santa Clara County, CA
- Air GT, XC40 P8 EV
- 3OKY7YGA
Lucid's LCHCS will require a neutral-balancing autotransformer in addition to a transfer switch to be able to power a home. This is a standard technology for solar inverters which only output single phase 240VAC. The autotransformer is a large center-tapped inductor which creates a neutral that is forced to be midway between the 240V legs, regardless of 120V load imbalance. I didn't know this at first either, and was similarly perplexed as to how the LCHCS could work in the USA for V2H.One thing I don't understand is the Lucid charger doesn't have a neutral.. I'm pretty sure that would be required for V2H to work. Someone with better electrical engineering skills can tell me I'm wrong.![]()
The Enphase system controller I'm planning to have installed in the next couple of months includes an autotransformer. Sadly it isn't likely to work with my Air if/when V2H is introduced.
