EZPass Mounting Location in the Gravity
Not wanting to stick my EZ Pass transponder to the windshield glass, I had it sliding around on the dash until I realized there's a perfect sized depressed area of the dash about in the middle of the Clear View screen on the windshield side of the screen. Completely out of view and works fine. FWIW
Does EZPass use different technology than Fastrak?
We drove up and down the Hwy 73 Toll Road in Orange County, CA last weekend with the Fastrak on the dashboard. It didn't register - they charged us via our license plate.
Ah. Great question. But unfortunately far beyond my knowledge level. I suspect someone on here will know the answer.
And now that my curiosity is peeked, (or peaked?), I looked into both Fastrak and E-ZPass. Quite different looking items both using RFID technology. My somewhat older NH version is a 3"x4"x3/4" plastic box with a 10 year battery, apparently. And, it "must be mounted behind and to the right of the rear view mirror on the windshield". Oops. But mine has been successfully read although they warn that the readings my be sporadic if not mounted to the windshield. 🤷‍♂️
Yes, would not recommend dash mounting. EZPass, IPASS, FastTrak all use a very similar toll reading technology and the upper mount area of the windshield (where Lucid does not have specific UV shielding tech) will provide good coverage for RFID reception. Here is a good explanation of the technology:
Modern tolling systems like E-ZPass and FasTrak use Radio Frequency Identification (RFID) to automate payments. While they might look different, both the older "hard" plastic transponders and the newer "soft" stickers operate on similar principles, managed by sophisticated overhead readers.
1. The Core Technology: RFID
The system consists of two main parts: the Tag (your sticker or transponder) and the Reader (the antenna on the gantry).
* Active Transponders (Plastic Boxes): These contain a small lithium battery and a microprocessor. When you pass under a toll, the overhead antenna "wakes up" the box, which then actively broadcasts its ID back to the reader. This provides a very strong signal.
* Passive Tags (Stickers): These have no battery. Instead, they use backscatter technology. The overhead antenna blasts radio waves that are powerful enough to "energize" the tiny chip in the sticker. The sticker then reflects that energy back with its ID encoded in the signal—similar to how a mirror reflects light.
2. How the Reader Handles Both
You might wonder how one antenna can "talk" to two different types of hardware. The secret lies in Multi-Protocol Readers.
Tolling gantries are equipped with "smart" antennas that cycle through different communication protocols (languages) hundreds of times per second.
* Polling: The reader constantly sends out "interrogation" pulses.
* Detection: It listens for responses. If it hears the specific "ping" of an active E-ZPass box, it switches to the TDM (Time Division Multiplexing) protocol.
* Sticker Reading: If it detects a passive sticker, it uses the 6C (ISO 18000-63) protocol, which is the global standard for battery-free RFID.
3. Implementation: Toll Booths vs. Open Road Tolling
The physical environment changes how the read is performed, but the underlying logic is the same:
| Feature | Toll Booth (Legacy) | Open Road Tolling (Modern) |
| Speed | 5–20 mph | Highway speeds (65+ mph) |
| Detection Zone | Narrow, focused on one lane. | Wide, covering multiple lanes simultaneously. |
| Sensors | Often use "treadles" (pressure strips) to count axles. | Use overhead lasers (LiDAR) to track vehicle size and position. |
| Backup | Physical gates or lights. | High-speed cameras for License Plate Recognition (LPR) if a tag fails. |
The "Handshake" Process
When you drive through at 70 mph, the following happens in milliseconds:
* Tripping the Beam: A laser or light curtain detects a vehicle is entering the "read zone."
* The Interrogation: Overhead antennas blast RF signals across all lanes.
* The Response: Your tag (sticker or box) sends back its unique ID.
* Verification: The local lane controller checks the ID against a local "whitelist." If it's valid, the transaction is logged.
* Camera Sync: If no tag is found, the system triggers a camera to snap your license plate, which is then cross-referenced with your account or used to mail you a bill.
(Credit Gemini)
(Credit Gemini)
Fantastic info! Now the question is what is it about the Gravity's windscreen tinting that is blocking transmission or registering?
Likely this:
1. Metallic Oxide (Athermic) Coatings
Many luxury and electric vehicles use athermic or IR-reflective windshields. These contain a microscopic layer of metal oxides (usually silver or titanium) sandwiched between the glass layers.
• Purpose: To reflect infrared light (heat) to keep the cabin cool and reduce the load on the air conditioning.
• Problem: This metal layer is highly conductive, which means it reflects the radio frequency (RF) signals back at the transponder rather than letting them pass through to the toll reader.
Yes, but what @illopp00 is saying is they put the IPASS sticker below , they are not able to be taken off and replaced, you have to order a new one to remount it.
I ordered a pair of these of Amz to mount my stickers, @illopp00 you may want to request a new sticker and trying using this: https://a.co/d/hdVcQB8
Ohhhhh, I see. I didn't realize they weren't removable. That explains it. Thanks for clarifying!
It may also be getting read through the quarter-window; those are not metallic tint. So if you have it close enough to there, it may work. But as you said, it will not be as consistent as if you mounted it properly to the right of the camera housing. Otherwise, you may heva different iteration of the windshield, potentially, without the metallic tint.
Same thing was true on the early Airs; you had to have it mounted in a specific spot. Eventually, later iterations of the windshield used non-metallic tint.
it's "piqued"...actually
Just an update, using the I-PASS sticker on the Pass Holder suction mount linked above, placed in the area just right of the camera ( you can see this area if you shine light as it has almost like a bubble pattern carve out) , my I-PASS sticker wasr recognized in the Open Road I294 tolls and immediately hit my account on a trip to the burbs today.
Not my favorite transponder location as it's very noticable area, but indeed does work.
Thanks to the groups advice, I consider this solved with that combination of the little holder and location. I had to look very close, there is a square 'cut-out' in the windscreen tint that is a like a grid/matrix pattern. Like @jace said, it's not the most pretty but it did work. Now I wonder what will happen to all the other tolls that didn't register and don't show up in my IPASS account:P
I bought the Amazon holder with the suction inserts, seams bulky. Will probably just use the sticker. The tip of looking at the window in the sunlight from the outside is very helpful to seeing where to mount the sticker on the inside. 🤓
I think the word you want is “piqued”. As in, your curiosity was “prodded at”.
I had PPF applied to my windshield on the exterior, and tint applied inside. Will this affect the ability of my RFID to be read?
No, but cops in California will love to write you a ticket for the windshield tint.
I’m not worried, it’s 70% tint. I was more interested in the so-called heat rejection properties than actually darkening the interior.
Yes EzPass (IAG) tags are different from Fastrak. They all build on the RFID technology but use different toll protocols. So yeah you cannot use your EzPass tag in California and you said you had it on the dashboard, doesn't surprise me it didn't read.
Validated! Checked my Illinois tollway account and see the toll charge after I attached the sticker. Shining the phone light to the left of the mirror ( from the outside,) as per this forum tip was very helpful.
