- Mar 28, 2022
- Orange County, CA
- V60 Polestar, AGT
- U5RO5CBT
Question.. How difficult is it to remove the panels to get access to cover up the 2 holes…The Earliest my center center can do the repair is next month..I was thinking on doing it myself…Update: Success!
Service (Frank) was at my house today to fix the problem with the woofer in the footwell on the driver side. I previously called in a subwoofer, but he corrected me… It is a woofer. Anyhow, the woofer sounded like it was "blown" from the beginning, so he brought a new speaker with him. The best way to demonstrate it is with the song "Need You Tonight" by INXS, move it the 1:00 minute mark and stick your head down inside of the car next to the dead pedal. Shouldn't hear muddy vibrations on the kick drum.
Since the time that I originally discovered the problem, more knowledge has been gained about it. It turns out it's not the speaker at all. Behind the footwell carpet is aluminum body and in it, two 1 inch holes. These holes are covered by a piece of tape that looks like duct tape, about 4" x 2". It turns out it was that very tape that would vibrate and cause the sound of distortion. Frank removed that tape and replaced it with some foil backed butyl tape (Pella window tape to be specific). Voilà, the problem was instantly gone. The sound system sounds amazing now. While he was at it, he also did the passenger football which had some of the same problem, but not as pronounced. So happy with the sound system now!
While we were at it, he worked on the steering wheel to get rid of the creaking plastic to plastic sound. He took it off and apart (beat that, Tesla, even cooler than your dorky yoke), then put foam spacers at each of the four screws that hold it together from the back. A couple squirts of WD-40 dry lube, and the problem is gone forever!
We are blessed to have Frank here, he's patient and helpful. Thanks, Lucid. Love my GT!
View attachment 7596View attachment 7597View attachment 7598View attachment 7599View attachment 7600View attachment 7601
It’s not that easy and there are a lot of little clips that you can potentially break. If it were my car, I would have service do it.Question.. How difficult is it to remove the panels to get access to cover up the 2 holes…The Earliest my center center can do the repair is next month..I was thinking on doing it myself…
Any difference in sound?Went ahead and got a buddy to pull the panel and seal the 2 holes causing the front speaker to bottom out….Such a simple fix….
Huge difference…..I can play my music loud with the bass set at 0 instead of -6db….No more bottoming out….I still plan to do a full system upgrade next month….Any difference in sound?
Is this photo before the fix? My system sounds pretty good, but I am curious if the system would sound even better after the fix. My mobile tech told me he couldn’t do it for me.Went ahead and got a buddy to pull the panel and seal the 2 holes causing the front speaker to bottom out….Such a simple fix….
Huge difference…..I can play my music loud with the bass set at 0 instead of -6db….No more bottoming out….I still plan to do a full system upgrade next month….![]()
After the fix sir…I think the factory tape they use to block the 2 holes is just too thin …Is this photo before the fix? My system sounds pretty good, but I am curious if the system would sound even better after the fix. My mobile tech told me he couldn’t do it for me.
If you go back and reread this whole thread, you will see lots of pictures and explanations.Is this photo before the fix? My system sounds pretty good, but I am curious if the system would sound even better after the fix. My mobile tech told me he couldn’t do it for me.
I am an audiophile junkie…I have yet to hear an upgraded Factory Hifi system that blew me away…I will say this….After streaming Tidal for the first time with the front speaker issue repaired…I am truly impressed with what I heard ( for a stock setupApropos of almost nothing being discussed here - I’ve already spent so much on the initial purchase of my Air GT already that I wouldn’t dream of spending even more money on upgrading the audio.
Having said that, in spite of being told repeatedly on this forum, by members whose opinions I trust, that our 55-speaker, hyper-megawatt, supah-dupah, extreme-ultra HiFi system designed into our Air GTs, is way superior to many - my ears still tell me something different. That the audio system in our Tesla Model X sounds better, sounds fuller, and sounds richer. I only wish I could hear it above the deafening road roar and intrusive wind noise.
Thanks to the forum for uncovering this problem and the fix. Today I was in for service and told them that the bass was not working properly, I even provided the description of the fix with photos. They were going to run some test and measurements to confirm the bass problem By the end of the service, they did implement this fix. Not sure why they were initially reluctant. Now the sound is much richer.I am an audiophile junkie…I have yet to hear an upgraded Factory Hifi system that blew me away…I will say this….After streaming Tidal for the first time with the front speaker issue repaired…I am truly impressed with what I heard ( for a stock setup)….The front stage sounded really good…but not good enough for me to pay the $4k upgrade to keep the SSPRO….
Okay. I am going to attempt to do this fix. Anything I should watch out for for this fix. I am hoping a don’t break anything.Went ahead and got a buddy to pull the panel and seal the 2 holes causing the front speaker to bottom out….Such a simple fix….
I hear the same in my car. Sounds like a blown speaker.I uploaded a video to demonstrate what I am hearing. I would appreciate it if any owners on here could please comment as to whether you think this sounds wrong. It sounds like the front left speaker is “blown” to me. It reduces the entire bass to being very muddy; no tightness. Does anyone else hear this? I am using a song in Atmos on Tidal.
Link:
