- Aug 12, 2022
- Buffalo, NY
- Lucid Air Touring
- BJ2URGEK
Just print one for Sapphire and see who calls you out on it
I like these but now I am running out of real estateUse the headliners from here. https://lucidowners.com/threads/new-video-the-escape.6251/post-148215
The specs and trim info, you want to talk about to anyone interested in the deets.
I'm saying don't put the specs and trim info on the print. Maybe only the HP and range. Use the headliners and a super sexy pic of the car to grab attention and draw people in. Then just talk to them about the trims, specs, and price if they want the deets. Sell the wow factor and your car on display will do the rest.I like these but now I am running out of real estate
This is good! Add the laguna seca time, and make the hp something like ”up to 1234 hp” and we should be set!Okay based on your input:
Let me know if more data you would cut or an Item you would include, Thanks!
Accolades
2022 MotorTrend Car of the Year
2023 World Luxury Car of the Year
Fastest Production Car at Goodwood 2022
World's Longest-Range Production Car
0-60 and 0-100 Speeds of a Hypercar
Highest Luxury Interior Materials
Latest Car Technologies with OTA Updates
816 HP
0-60: 2.9 seconds
EPA Range: 516 Miles
Charging
Standard : Combined Charging System (CCS)
Voltage: 300 KW
AC: 19.2 KW
Speed: Up to 200 miles in approximately 12 minutes
Chassis
Suspension: Semi-Active Dampers
Torque Vectoring
Vossen 20 inch HYBRID FORGED SERIES: HF-4T
Yes, that is the laguna seca "time." Sapphire is 1234 hp. If you wanted to, you could also put some info about the motors(how light it is, 670 hp..)Is that this?
Overall, the same Lucid Air Grand Touring Performance car used at Goodwood took a mere 38.89 seconds to finish the course, winning out by nearly six seconds against the 950-horsepower LaFerrari. The five-seat sedan carries a powertrain utilizing two motors that combine to push out a staggering 1,050 horsepower, but it also wins out on the Prancing Horse thanks to the electric system’s instant torque response as well as zero shift times.
And up to HP is the Sapphire?
I'd say "up to" for hp, range, etc... To capture all the trims in one chart.Okay here is a revision:
Any changes needed ??
I am thinking maybe more spaces on left side
Under charging and Voltage: Voltage is measured in Volts, not kW. Note the k in kilo is not capitalized. Power is measured in kW, not voltage. Voltage could be 924V for the pack Voltage when fully charged.I'd say "up to" for hp, range, etc... To capture all the trims in one chart.
Same with the 0-60 speeds.
Yeah I was thing to change voltage to charge rate or speedUnder charging and Voltage: Voltage is measured in Volts, not kW. Note the k in kilo is not capitalized. Power is measured in kW, not voltage. Voltage could be 924V for the pack Voltage when fully charged.
I like the information listed on this better than the v.1 eye chart. Personally I'm not fan of the font because the all caps seems to be screaming but that's a subjective opinion.Okay here is a revision:
For range, say "up to" as well as for the 0-60. Fastest lucid air is 1.89. If you dont say "up to," then somebody could buy a pure and think it has 516 miles..
This made me spit out my drink and almost killed me this morning from a coughing fit.I like the information listed on this better than the v.1 eye chart.
Pretty soon forums will be AI, thoughts ??
