- Dec 31, 2022
- Air Pure
Something new I learned is electrical company (NYSEG in Upstate NY) will swap out existing meter with a Day/Night meter which will result in a lower kwh rate for both day and night.
That’s the way it is on L.I. too.In CA, many have access to time-of-use rates. But this results in a high on-peak rate with a low off-peak rate. The non-time-of-use rate is in the middle.
Day off, right before you leave. Don't let the car sit at 100% for too long.I am planning to go on a long road trip this weekend and was wondering if it is better to full charge (100%) the day before the trip or the day of the trip. Any thoughts or does it not make a difference?
Thanks!
Perhaps set it to charge to 95% or so and then finish it off in the AM before one leaves?Day off, right before you leave. Don't let the car sit at 100% for too long.
Daily charging is the standard recommendation for most manufacturer's EVs.Lucid wants to hide the vampire drain problem so their recommendation for daily charging helps that issue, noting to do with battery life. I am losing 1% SoC every 24 hours.
Love this philosophy. Should we crowdsource T-shirts with a fake movie poster: Dr. Strangejoec, or How I Learned to Stop Worrying and Love the ChargeYou'll hear lots of conflicting advice on this matter. And lots of points of view from folks with more electrical knowhow, etc.
The best advice I can give is to not stress about it. Keep it between 20 and 80% most of the time. Top up to 100% when you really need to only. Then stop worrying.
It's actually pretty hard to damage one of these batteries, unless you are actively trying to damage it.
This is great advice. At home I have max at 80% and plug in when I am below 50%. For some road trips I go to 100%, I also sometimes leave the house at 80% if I’m going to use DC fast charger and 100 has little value. I don’t anticipate owning this car for more than 3-4 years, so I don’t stress about it. On the road DC charging, I charge to 80-90% as the last 10% just not worth the time. Nothing to do with battery life.You'll hear lots of conflicting advice on this matter. And lots of points of view from folks with more electrical knowhow, etc.
Great data here in the chart from GMan. Before getting my Lucid Touring I had a Tesla Model S for almost 10 years. I too charged it every night and almost never above 75%. My wife has it now. I'm curious to see how long it will go.
There is calendar life degradation also. Typically 1.5% or so per year, depending on Chemistry. Does anyone know if Lucid uses NMC or LFP? And who's cell? My guess is NMC given the rapid acceleration needing a high C rate battery. It is true that battery companies have their own engineering magins applied, so 100% is not really 100%. But the buffers vary significantly by manufacturer. I think the once a month charge to 100% is to reset calibration as there is drift on calculation of SOC. It also helps with cell balancing (ensuring each individual cell and module are at equivalent SOCs).Okay Deane, that's even better. I was happy with the 19 years in my incorrect calculation above. But now with your correct information it is far greater than 19 years. So I will just continue to charge when my SOC gets down around 25% and charge up to 85% and not even begin to worry about battery degradation. I probably won't even charge once a week unless I'm doing a longer trip. I did read on another manufacturer's forum that their manual states it is good practice to charge up to 100% once a month or so as long as you don't let the car sit at that 100%. Also, apparently that manufacturer has a built in 5% buffer reserve so when you charge to 100% you are actually only charging to 95%. Not sure what buffer/reserve my Lucid has if any?? Also, not sure it really does make sense to charge to 100% once a month??
Lucid is using NMC from LG and Samsung.There is calendar life degradation also. Typically 1.5% or so per year, depending on Chemistry. Does anyone know if Lucid uses NMC or LFP? And who's cell? My guess is NMC given the rapid acceleration needing a high C rate battery. It is true that battery companies have their own engineering magins applied, so 100% is not really 100%. But the buffers vary significantly by manufacturer. I think the once a month charge to 100% is to reset calibration as there is drift on calculation of SOC. It also helps with cell balancing (ensuring each individual cell and module are at equivalent SOCs).
LOL, c'mon, that Launch Mode should snap ya right out of it.Sometimes it’s simply a matter of remembering to plug in, depending on how catatonic I feel after getting home from work.![]()
