Creaking noise when rolling to stop
To my understanding, HOLD applies the electric brakes upon a stop.
Making noise as they release also makes me think it could be sticking disks, which EVs are notorious for because most of us drive fully in regen and rarely apply the friction brakes, which in turn get dirty/rusty.
Try coming to a stop with vigorous use of the brake pedal a few times to clean the disks of rust. It might go away if so; easy fix to try.
But I agree it is worth keeping an eye out for the loose half-shaft recall issue. Be safe!
You also get sticky calipers (pistons) from not using the brakes periodically
Unless you like doing a brake job due to corrosion
Try roll with regen on. That will separate automatic brakes from driveline.
The car is already in service and awaiting the front drive unit replacement.
I had the same problem. Initially, they told me they would replace the drive unit. However, in the end, all they had to do was retighten the half-shaft nut to torque spec. My car sat at the Atlanta service center for 2 months to do this, but that is another story.
My car is in service already for almost 3 weeks because of that and they haven't even started to work on it (San Jose, CA center). I am not surprised and don't expect it to be repaired any time soon.
So I have my 2025 AT back from service, took about 3 weeks in San Jose, CA. They ended up not replacing the front drive unit did but just replaced some nuts (Technician removed old LH & RH axle shaft nuts 32mm and replaced NEW axle shaft nuts LH & RH 32mm and tightened spec. 220 N-m. performed test drove, creaking noise are gone). I also had a tear on the left bolster of the driver seat and the easy entry option was not working. So they replaced the whole driver seat assembly. Additionally, the cruise control was engaging only intermittently, they checked it and apparently the cruise control button was malfunctioning, and they replaced the whole steering wheel. Finally, they replaced the wiper blade inserts because the left wiper was leaving streaks on the windshield. Overall, a little long but not too bad and the issues seem to have resolved. They also updated the software to 2.11.0.
Yes, it was related to hold. The sound went away in roll mode with regen braking off.
My 2025 is doing the same.
Try with regen off and drive it like automatic ICE, does it creak? I suspect is actuator for brake pedal when the car is coming to a stop with HOLD.
Wanted to give an update on my situation. Out of frustration, I tried with regen braking off again while out on the road, and can confirm the creaking noise largely goes away. However, it’s still there when you start the car from a stopped position, or after reversing. I took a video to show the difference:
It seems the regen braking system is completely shot.
Also, on an unrelated note, the internet went out in the car.
I really don’t want to have this car in the shop for three months.. doesn’t seem like I have a choice though. Super frustrating.
My car came back just now, noise is gone and better than new.
To elaborate, not only the cluck from torque related noise is gone, the "thump" noise for HOLD and "unHOLD" since new is gone too.
In Dubai, they took my car away on Sunday and its back today so total about 3 days.
I understand in the US service centre is more backlogged but just sharing the job itself shouldn't take 3 months.
Now back to dealing with Mercedes recall.
congrats man, I dream of an outcome like this.
The service manager said it was ting washer, just looked it up such a small component. Not to defend Lucid or bash Rivian, also found this on Rivian group.
I’ve been knowing this.
Maybe they should authorize other garage to do this job.
My car was much louder than your video, it was embarrassing when pedestrian looked back at my clunk.
they should indeed. It’s clearly not that difficult of a job. I learned about the fix when I had a Chevy Bolt EUV. The third or fourth post on this thread gives a pretty thorough explanation of it: https://www.chevybolt.org/threads/creaking-sound.43561/?nested_view=1
I wish I had a technician I could ask to do the job, but I don’t. I bet I could do it myself, but I don’t have the tools or access to infrastructure to work on it properly.
View attachment 42178View attachment 42179
I sent you a DM about this and haven’t heard back, but would you be able to share the exact part number for the ting washer that they used? I am considering doing the repair myself. Would also like to know torque specs for the axle nut, and also the part number for the axle nut. I imagine the Lucid technician listed a lot of information on the work order. Anything you can share would be helpful. It is so painful driving this car around, and my service appointment isn’t until January 18..
it’s definitely not the case. the creaking occurs when accelerating from a stopped position. what does the brake have to do with that? it’s the same thing as all these damn EVs: the half shaft bolts on the axle where the powertrain is connected. too much torque and the washers are worn. I honestly don’t even think they changed the fasteners during the recall.
Well to go from break on/stopped to moving requires the breaks get released, same sound? I get it when I stop and when I start. Breaks (dis)engaging is what I hear is your sound different?
Excuse me for jumping in, but break release/engagement sound is normal and sounds like "crunch".
But the tin washer issue is when you put a little more torque in when the vehicle is already moving you would hear a "clunck".
The brake release crunch is only in the car, but cluck from ting shaft is loud outside if you roll down the window to hear it.
it is very different
