- Oct 31, 2023
- SF Bay Area
- M4, CTR, R1T, Air T
- OV9HL03Y
Nothing to worry about at all. Just plug and go. To disconnect just yank it out. You can actually do the same at EA. Press the button on the ccs charger and it’ll stop charging and then you can just pull it out. You don’t have to stop charging from pilot panel or anything.Is it as simple as just plugging in the Bolt's J1772 plug, and away you go, or are the steps to take in advance on either the pilot panel or the app? When ready to stop charging, is a stop charging button available to push, similar to how you can stop charging from the pilot panel at an EA station. I assume you don't just try to disconnect the J1772 while charging is in progress. Thanks!
