DTA
Hey LUCID owners & enthusiast!
For those of you that took delivery of your Air prior to April 2022 and installed an EVSE at your home you are likely to have experienced the 'dredded circuit challenge' that occurs as our desert temps rise during the summer months. And, if you haven't then I [along with others] would greatly appreciate you weighing in on this thread. This is my second AZ summer as a AGT owner (as I took delivery of my AGT in early Q4 22) and before we could cross over into the summer season this year, we began experiencing the same heat challenges as last year due to the +110 degree temps.
As noted in a thread last year, I mentioned we installed a dedicated circuit (with all the appropriate components to compliment both the Juicebox EVSE and our AGT) and we [still] experienced heat factors causing the circuit to trip. As many of us are living through a second and/or third summer (with some experiencing this for the first time) here in the AZ, I am interested in learning how my fellow LUCID owners have maintained their equipment on the circuit that charges your Air. I have checked my dedicated circuit from the 50 amp [SquareD] breaker through to the Hubble 240 socket, the Juicebox EVSE power connector & cable, along with the Juicebox supply cable [to the AGT] and with the exception of the breaker all seems to be functioning properly. I am changing out the breaker as it will not [fully] reset. I suspect this is attributed to the excessive heat (as it is designed to fail and protect everything on the circuit).
For those of you who have dedicated circuits for an EVSE and have experienced 'heat failures' during past summers that caused you to troubleshoot the power failure point along the circuit, my questions are...
A note: last summer when the heat caused our circuit to falter I defaulted to charging at EA for 3.5 weeks until the circuit was repaired and I was able to charge. And although it's great to have the luxury of charging for free on EAs level 3 network - my reality tells me there are several more EVs [today] using those same EA chargers in the local area. And having to stand in line [even during the coolest time of the AZ triple digit days] to charge could increase tensions and cause other social challenges that we've seen occur in other markets across the country. I'd like to avoid those situations at all cost and keep my level 3 charging experiences to those while traveling between states.
I appreciate your comments & feedback and hope the information helps to solve a common challenge we all deal with in the AZ (and other excessive heat markets). Thanks! DTA
- Do you use the LUCID [mobile] EVSE provided with your car? Or do you use a different brand (e.g., Juicebox, Charge-Point, etc.)?
- Have you had to change out the 50 amp breaker your EVSE sets on since installing it?
- Have you had to change out the 240V socket your EVSE is plugged into?
- Have you installed a ventilation and/or a garage cooling system (i.e., split AC unit, etc.) to reduce the heat in your garage?
