- Jan 25, 2022
- Los Angeles
- Gold Lucid Air DE
- Air DE Number
- 195
Are you available Saturday mornings and what do you charge?Okay so here we go, prepare to spend money!
Since you have a pressure washer, buy this
Also buy 2 5 gallon buckets and...
A Grit Guard
Get 2 of these in different colors
A LOT of microfiber towels
Some window towels
Glass Cleaner
Opti-Coat Opti-Glass Clean & Protect 16 oz. - Opti-Coat
Opti-Coat® Glass Clean & Protect is designed to clean and boost your Opti-Glass™ Pro Coating with a simple wipe on, wipe off application. It will clean glass surfaces without streaking while the polymers will bond to glass surfaces and continue to add protection every time you use this product...www.opticoat.com
Wheel Cleaner
Okay now you are ready.
Fill both buckets with water, get both mits soaking. Spray your car, hook up that foam cannon and foam away. Using only 1 mit, wash foam on car. After 2 panels (my preference) rinse out in bucket with grit guard. Rinse again in other bucket. Continue until car is washed. Rinse off. Use 2nd mit now and use the wheel cleaner. Clean and rinse wheels. Grab your leaf blower and blow car from top down, get into the grooves and get that water out. Dry with microfiber cloth. After dry, take the Glass Cleaner and clean glass with the glass towels.
If you have ceramic coating, then you can get this https://www.opticoat.com/product/opti-coat-hyper-seal-16-oz/ to help top up the ceramic, but only need to do it once every 3 months or so.
