AirPlur
TL;DR: You apparently don't need to plug in your Lucid to keep the high-volt batteries conditioned and happy. Just charge when you want miles, need to keep it in its 20%-80% happy place, and to power the BMS to keep temperatures regulated in ambient extremes.
I've obsessively been hunting down an answer for my question of whether my (2-weeks-in-possession) Air should be plugged in whenever parked, whenever possible, even with no intention of gaining miles (i.e. using the stage 1 120v option) - even if it's fully charged to whatever preset I've selected. Sparing the full hunt and all the back'n'forths inside and outside of Lucid contacts, here's the most conclusive information I've received so far, straight from the lovely folks at Lucid customer care:
"This topic has certainly been one that we've had a lot of conversations about in office. The general consensus is you can leave it plugged in if desired, that would not cause harm or any battery loss to the car. It's not necessarily a must to keep it constantly charging, especially since the charging option with that 110-120V outlet may not provide you the most efficient use. One of the things to note too is if we are using the car on a daily basis, keeping it set on Daily or 80% would definitely preserve the vehicle's battery health.
I think in terms of what the owner's manual shares, it's kind of under the assumption that someone travels a fair amount. If we were using quite a bit of charge each day, then I would certainly recommend to plug it in every day/night to make sure you have enough charge for the morning. However, if we were driving maybe on average 30-40 miles a day, then charging every night would not be needed.
So really in short, I think for daily use, it is more than okay to not plug it in every day/night. It doesn't harm the battery if you do, it would just keep you at the top of the range given the limit it's set to. If we were travelling fair distances, it would be a good idea to make sure that we keep it plugged in and charging. That way, you won't have to worry about losing charge during your travels.
Let me know if that helps/makes sense!! I pooled a bit of wisdom from some folks in my office as well as some articles and personal experience with EVs. I hope you had a phenomenal weekend and a stellar start to your week ahead!"
Friendly people, right? So what I'm gathering here is that I shouldn't expect any great or minor harm caused to the high-voltage batteries if I don't leave it plugged in whenever possible while parked. Good news in my case since that means 100% of my charging can be done between my office and EA stations, with the stage 1 charger as truly a last-resort backup option. Hopefully that's helpful to others as well!
