Aftermarket Wheels for Gravity
It must have been modded. I have had almost no cars mess with me with maybe two exceptions. There was a MBZ and a BMW - both on the freeeway on a long trip. I think they just wanted to check out the acceleration. Yeah, not even a contest - obviously. Otherwise, pretty solemn and quiet.
Mine is dark and not obvious, then again, nobody knows what it is.
My new wheels are here! I think they look badass.
Tires (265/40R22, 285/40R22) will arrive soon.
I look forward to finding out what penalties I'll incur due to the increased wheel weight (~50lb).
That is definitely going to be a unique wheel design for the Gravity!
Here are my new wheels installed. I absolutely love how they look and fit!
Thanks to @037 for being the 1st to figure out custom wheel specs for us.
Because these are heavier wheels (+10lbs of unsprung mass),
I do experience a noticeable difference is ride comfort over bumps and road imperfections.
I am considering another set of custom forged Magnesium 22" wheels in the same style.
They'll be about 30lbs (40% lighter).
Currently, there is a shortage of 22" Magnesium blanks in China!
Those look good, any chance to get you to be the first one to space stock wheels out 1”?
This is what you need, fairly plug and play and the ride should not suffer and should look good but better.
I am waiting on factory to source 22" Magnesium blanks.
Otherwise, I'll return to factory 22/23" wheels (maybe with 1" wheel spacers).
If you do an inch let us know if you rub, I’m very curious. @037 and I are at 20mm poke which is 0.78”. On low, I’m very close to rubbing but surprisingly don’t with about 0.25” of clearance.
I guess I should mention that 25mm will work best for the base 20/21 wheels which are narrow to begin with. The 22/23 should buy a single spacer to confirm front fits ok.
I've decided to go with custom 21" Magnesium wheels (Black/Gunmetal).
Ideally, I would've liked 22" Magnesium wheels, but blanks for 22s are very hard to find.
Front - 21x10, ET30 (20.4mm Poke out) - 12.4kg/27.3lb
Rear - 21x10.5 ET36 (21.4mm Poke out) - 13.2kg/29.1lb
Tires - 275/45R21 (34lb), 285/45R21 (37lb) - Pirelli Scorpion Zero A/S (ELECT, PNCS)
Per wheel, I'll be about 8-10lb lighter that OEM, and 20lb lighter than my current HEAVY custom ones.
Needless to say, I look forward to reaping the immense benefits of much lighter wheels.
What does the cost look like vs your last attempt?
$5,500. Includes custom Gunmetal paint, taxes and shipping by air.
22" Aluminum wheels were $3,400.
How is the strength compared to last, weight rating?
Those stats are amazing for such a busy looking wheel (as opposed to nothing but think spikes for most wheels in that weight range).
Wow interested to see how much range you’ll gain. Let us know when you find out!
My Aluminum wheel load rating is ~2200lb, and Magnesium is ~2100lb.
Strength-to-weight ratio for Magnesium wheels is superior to Aluminum,
with excellent road vibration absorption compared to Aluminum.
BUT, Magnesium wheels will likely crack and/or shatter when going over deep potholes at high speeds.
Such damage is not repairable. That's the only downside.
As long as I can avoid deep potholes, I'll be fine.
I purchased a Gravity GT for my wife at the end of December. We both hated all of the wheel options Lucid provided and I was appalled that the 22"/23" setup cost around $8k extra. I never ride stock wheels in any of my other vehicles, so I figured "The Mothership" as we call it shouldn't be any different.
So, I created my own custom wheels with the help of Splux Forged Wheels. The wife is a big Lakers fan and wanted a pop of color, so I designed the inner barrel in a purple finish, added my own personal logo and a few other custom touches. I had to provide all the measurements on my own, but luckily this forum and some research of my own helped. I ended up going with a 22" setup all around running 9.0 in front and 10 in the rear.
From design to delivery, these took less than 2 months. I got them installed 3 days ago and have received MANY compliments since then. I like my vehicles to have some kind of personality and I've found the inner barrel being colored provides just enough of a pop to catch the eye, but it's still subtle enough to not be jarring.
Next I need to paint or wrap the hideous olive green/tan brake calipers. I didn't notice them previously because the stock 21" wheels covered them completely. If anyone is considering an aftermarket setup, I definitely recommend Splux. Chloe (a male) was extremely communicative from start to finish and the wheels arrived 2 days after being shipped!
What offset did you decide to go with, front to back? 265s on 22’s generally call for 9.5” wide wheel. But I see you went 275…
Wheel weight?
Wheel weight?
Offset is ET38 front and ET38 rear.
Specs ended up being:
22x9.0 front
22x10.0 rear
5x120
64.1 CB
ET38 all around
Tires are:
275/40R22 front
285/40R22 rear
I initially considered 265s up front, but after digging into Pirelli’s recommended rim width range (9.0”–11.0” for the 275/40R22), the 275 is completely within spec on a 9” wheel. It’s not stretched & not outside manufacturer tolerances.
You’re right, 265 is commonly paired with a 9.5”, but 275 on a 9” is still fully compliant & gives a better front contact patch for a 6,000+ lb EV SUV. That’s ultimately why I went 275 instead of 265.
Wheel weights are:
32.8 lbs front
33.9 lbs rear
Forged construction.
Clearance has been perfect so far. No poke, no rubbing, no weird steering feel. ET38 keeps it conservative and OEM+ rather than aggressive.
If anything changes after a few hundred miles I’ll report back, but right now the setup feels planted and looks exactly how I wanted it to. 🫡
22x9.0 front
22x10.0 rear
5x120
64.1 CB
ET38 all around
Tires are:
275/40R22 front
285/40R22 rear
Wheel weights are:
32.8 lbs front
33.9 lbs rear
Looks great!
Love the Purple!
