- Sep 7, 2024
- Hilton Head Island, SC
- Air Pure, Lexus RX
- ML46XAMX
Being an Electrical Engineer I was curious about the key fob short life mystery, as it has hit me also. (New 2025 Air Pure). So I made some actual measurements
First, the Fob is made by a British Co. called Pektron. Their website has no Specs on it.
Next I took a microammeter and measured the current draw under the 3 conditions below:
1 - Qiesecent (far away from car): Very variable, changed about once per second in range from Approx 10 - 200 microamps.
2 - Pushing the button = 800 microamps.
3 - Sitting in car, with car on and in drive. Similar to #1 but seemed to peak at 400 microamps.
Let us reduce each of thse peaks by 1/2 to account for the duty cycle of the pulse in order to get an average draw. Thus, the averaege draw is about 100 - 200 microamps. More precise analysyis would require an oscilliscope.
The CR 2032 battery in the fob is rated at 225 mah = 225,000 micro-amp-hours. Thus, doing the simple math, at 200 microamp avearge draw it would last 47 days. At 100 microamp average draw it would last 94 days. At 50 microamp average draw it would last 188 days = 6 months. That is what many of us are noticing.
Conclusions:
1 - The fob must be scanning or has a high quiesent draw that is pulsed in some way to reduce average drain. A Farady shield is not going to fix this.
2 - None of my other cars have this problem. So better designs are possible.
3 - I am starting to think that Lucid owes us a new fob
A quick fix would be to add an external on-off slider switch in series with the battery.
Cheers,
Steve
Conclusions:
Cheers,
Steve
