2.6.11 Update
Anybody having issues with charging since the update? Mine randomly starts and stops. I'm using the Lucid mobile charger at 30amps on a dryer outlet. Nothing has changed but that. Was charging when I went to sleep last night and woke up and it had stopped 5 min later. Vehicle didn't charge overnight but soon as I opened the app it started charging again. I'll do a reset but just curious.
Check your wiring and receptacle.
Try charging again during the daytime. After 30 minutes of charging, or when charging stops early, did the mobile charger flash any lights? Pull the mobile charger's plug out of the dryer outlet and feel the plug's prongs. They should feel warm but not hot. If hot, you should have that receptacle replaced with a commercial grade / EV-rated unit. The part will cost about $50 rather than the $8.39 residential version at Home Depot.
Also make sure the mobile charging adapter's 14-30 plug adapter is fully pressed into the mobile charging adapter.
I got a "Door Failure" fault during my first drive after the update, and the red door icon stayed illuminated during the rest of the drive. It didn't reoccur after I parked the car for a few hours. I've had many transient random errors in the last two years, but it is unusual for the warning light to stay illuminated. A door error seems like too much of a coincidence after a software update intended to fix door issues.
I thought the mobile charger pulled 40amps and wasn't adjustable. Wouldn't this be tripping your breaker?
just got Dose of 2.6.11 robustness and did the update but have not gotten the time to test if there is anything Odd
FYI I have AGT 23
Did anyone go wtf when they read this patch update cmon Lucid we need to get doors opening and closing. Feels like backward progress on software
What makes you think this is a new issue? For all you know, this has been there forever, and they only just discovered the bug.
