- Jan 3, 2022
- Santa Clara County, CA
- Air GT, XC40 P8 EV
It certainly seems that a couple more minor bugfix releases would be helpful near-term.
Just out of curiosity what's the production date on your vehicle then when it was delivered....I must be part of the minority. Since .47, my car has been remarkably bug free. Most error-free update for me to date. Even SXM seems reliable. Only issue I still have is with the mobile key. Sometimes it opens immediately, sometimes it takes 10-20 seconds, which is a long time if your hands are full.
I took delivery October 11. Not sure of production date.Just out of curiosity what's the production date on your vehicle then when it was delivered....
put the steering wheel in a lower position and then see if it goes, the camera is located on the very bottom chin of the glass cockpit, so it needs a clear view from above the steering wheel from the bottom chin of the cameras (you'll see little red dots, it's around that area)I too have had pretty good luck. Sirius mostly stable. Had to do one or two resets for various things but overall solid.
Only consistent error I get is “Driver monitoring unavailable “. I get that on nearly every trip. Nothing is blocking the camera. Steering wheel is high enough.
This is a Touring mid-December delivery.
I concur with that fix. When steering wheel is too high, it blocks the camera. There's another thread on this point. Lower a bit and you'll be good to go...put the steering wheel in a lower position and then see if it goes, the camera is located on the very bottom chin of the glass cockpit, so it needs a clear view from above the steering wheel from the bottom chin of the cameras (you'll see little red dots, it's around that area)
so you may have the steering wheel too high
How do you get navigation voice prompts via alexa? I cannot get any audio turn by turn to work on my car and I'm on .47Alexa did work great again with .47, and my navigation voice prompts came back too.
what happens when you input a destination and say go?How do you get navigation voice prompts via alexa? I cannot get any audio turn by turn to work on my car and I'm on .47
Mine just started working again by itself on .47How do you get navigation voice prompts via alexa? I cannot get any audio turn by turn to work on my car and I'm on .47
