Wind Noise
Interesting, SC believes that PPF on the side mirrors contributes to wind noise. Has anyone else heard this?
Nope. Unless it’s flapping around, I’d tell SC to continue investigating.
Whaaaat….? First time I’ve heard of this.
Same, and I’ve had PPF everywhere, including but not limited to the side mirrors, since my car was delivered.
Said that it changes the speed of the airflow around the mirror. Stated that testing has been done with/without PPF. I was quite shocked to hear this. Not sure I believe it either, but just reporting what they told me this morning. I’m 100% PPF’ed.
I’ve never heard of PPF changing anything like this. Mine are PPF’d and ceramic coated, so they are very slick.
Same. I can’t speak to non-ceramic coated, I suppose.
My car is a lease, I have neither ceramic nor PPF. I had no whistle for over a year, then it just showed up one day. No idea what changed, but it wasn't any kind of coating or film.
If not already done, perhaps this TSB will solve your wind noise problem. It solved mine.
Job: TSB-C0324-005-01 Loss of retention from Side Door Glass Run Seal
Concern: Client states the driver rear upper run channel molding is popping out. Please check and advise. Confirm proper fitment.
Cause: The side door glass run seals lose retention and separate from the door frame.
Corrections: Performed -TSB-C0324-005-01- Install retention clips on all side door glass run seals.
Has there been a solution to this? 2025 Air 60mph and higher has a very annoying whistle.
Big NOPE...Get in line...I've been struggling with this one since I got the car in 2023...tried various things and shared them here and lessons learned...this one issue seems tenacious...
I’ve had this issue with my Chevy Vokt and my Tesla X. Only solution is to crack a window or two to eliminate the buffering whistling noise.
I’ve come to ignore it. The wind noise coming from upper part of the driver’s window comes and goes.
It’s more likely to happen, and more pronounced, when I first drive the car away from my house, where my car has been garaged. The whistling, wind rush noise becomes muted and sometimes goes away completely, the longer I drive the car.
