Wheel Offset info on Gravity
HIGHFLY
Irvine, CA
2024 Lucid Air Pure
Wondering if there's any wheel width/offset data publicly available?
I'm planning to get a custom set of wheels in the Shappre design for my upcoming Gravity, working with the same company I used before.
Here’s the rendering they sent, this is exactly how I want my Gravity to look! Except I will be chaing the blue ring color to Bronze to match the Supernova Bronze.
Any info would be appreciated!
Took me over 6 months to confirm the bolt pattern is 5x120… unless someone pulls a wheel we got nothing.
If I do get my GT your odds will go up as I will pull the wheels off…
Thanks, good to know. Now I just need to find out the width and offset!
Based on TireRack tire sizing the wheels will
Be 9”-10” wide and they go wider as they grow in Diameter, so base rear is probably 9.5” and 23” rear is at 10” a the tires go from economy to performance.
That's a good point.
After I look close up to the website and some youtube video, here's the spec:
Front 265/40/22 22x9.5
Rear 285/35/23 23x10
And check this out... whopping $924.62 per tire for the 23" !! (Front tire listed at $554).
$3000 for tire replacement.!
maybe the economy of scale will help as more Gravitys are delivered. :)
I'm hoping mine will last 3 years after looking up those @ tire rack a month ago.
-iThinkEV-
Large size 22” front: 22 x 9.5 and 44 offset, 5x120 bolt pattern
Medium size 22” rear: 22x10 and 51 offset, 5x120 bolt pattern
Thanks for posting! Any info on the 21" wheels? I am thinking about getting winter tires on 21" so as not to have the staggered setup Lucid is going to offer and have to pay crazy money for winter tires for ever
Any idea whether the large wheels are forged?
The front 22” is estimated at 45lb, I asked for a number on a scale, if I get that I will share, otherwise that is a very very heavy wheel.
Not that I can dig up but as far as width, the 22” above should tell you exactly how much poke to look for, smaller wheels will be narrower with a higher offset.
I see no reason why they would push the smaller wheels in, they all should look the same from the outside, my thinking anyway.
