Firmware Updates in Germany
It’s so weird that my Air is still showing 2.1.1 as up to date. Did you have to do anything on your end to get it to show the update available for download?
Up to date just means there is no update available for your car specifically. They’re rolled out in batches, not available to everyone at the same time, so that bugs can be caught before everyone is stuck with them.
I tested the new 2.6.5;
What I liked:
- on main screen; when you choose Smooth, Swift or Sprint mode; you can directly choose the type of Regenerative Braking between Off, Standard or High without the need to Navigate through other menu's.
- also the Warning/Confirmation window to acknowledge Sprint mode has disappeard which is great, one button less to touch each time.
- in the app I can now remotely precondition the battery and open the charging port, this saves sometimes opening the driver door and pushing on the button to open the port.
What I disliked;
- somehow I have to enter my pin-code each time I want to drive away. Normally this only happens when I forget my key. Don't know yet how to switch this off
- extra soound warnings Maximum speed and Speed update; but I could turn them off, not sure if I have to do this each time.
What I didn't understand:
- In the help menu I could see some examples of the Hey Lucid voice control, the example texts were written in Dutch language, but clearly after speaking those commands, I'm sure the car only understands English.
What I disliked;
I had the same issue with the mobile key (phone) not working correctly after the update. I just deleted it on my phone and paired it again and now everything is working (maybe even better than before).
The sound for the speed limit is turned on every time you start to drive. This is, afaik, a EU regulation, but only for new cars. Very sad that Lucid decided to implement it in existing cars.
It seemed to me as if it was an english voice trying to read german text. After I reinstalled the german language pack it was working fine.
But the lucid assistant did not understand me well. Even the suggested commands (from the manual) worked only half of the time.
Thanks for the Info! Will be getting an Air Pure AWD soon (in Germany) that supposedly is already upgraded to 2.6.5. What's your experience regarding the stability of the maps app and the reliability of the software overall with 2.6.5? That was an issue during my test drive a few months ago...
I received and installed the update yesterday for my Air DE.
The single biggest noticeable change is the insane improvement of the Sound System.
CarPlay has so far been 100% stable as has been the Lucid Nav app. The entire OS feels snappier, less cluttered and the new functions are pretty ace as well.
Another update is currently loading, version 2.6.9
The release notes mention further improvements to the DD Pro Sound system.
For some reason, none of the EU updates as well as this one are mentioned over on lucidupdates.com
@Bobby lives in California, and manages lucidupdates.com on his own, so we don’t see the European updates!
@Bobby - any interest in making an EU timeline? Or rather leave it for someone else?
That would be great, after I downloaded last version, my FOB stopped working, so everytime I have to use the app to open my car which takes too much time.
Also couldn't connect/link the fob anymore in settings menu. Mentioned it to Lucid Service but no reply so far.
Maybe with this new update this bug will be resolved?
I received the update today in Germany. The audio alarm for speed limits is very annoying but you can easily disable it.
The lucid assistant is completely useless at the time.
And I could not find everything mentioned in the release notes.
Since this last update every time after I activated the park mode it will beep if I go very little over the speed limit and you have to disable it every time again manually it doesn’t remember and keep it setting which is rather annoying and did work before I would to memorise my setting but every time you start driving, you start from scratch anyone has an idea how to solve this?
Does anyone uses a dash cam? How do you get electricity for the camera? Is there any update that the Lucid itself can use the installed and available cameras of the car?
There's a dash cam thread with install tips: https://lucidowners.com/threads/dash-cam.966/
No update on if/when Lucid will have a dash cam feature built in. That has never been promised.
Lucid Air Firmware 4.7.2 is out. Just installed it and it comes with features and improvements in these areas:
  • Android Auto TM
  • DreamDrive Pro
  • Intotainment
  • Drivetrain
  • Soft-close Doors
  • Sapphire
See screenshot enclosed.
I'm guessing this is only available in Europe since it's already 4.8 in the US and I can't find anything mentioned on lucidupdates.com. I just submitted it there...
  • Android Auto TM
  • DreamDrive Pro
  • Intotainment
  • Drivetrain
  • Soft-close Doors
  • Sapphire
Great, saw the update in my Dutch car also, now on holidays, will try it out next week.
Hey @LUCID9666
That's not a bug. as of July 2024, it is mandatory for all new cars sold in the European Union to be equipped with an Intelligent Speed Assist (ISA) system that alerts drivers when they exceed the local speed limit.
Since we have a different update path in Europe I have started a new thread where European Lucid Air drivers can post about new Over-the-Air Updates and their experiences:
Lucid Air Updates for Europe
I can confirm US cars have a different update path than Europe. LucidLogger / TeslaLogger is tracking versions and 2.7.1 are only available in US and 2.7.2 only in Europe.
If anybody want to share their firmware / charging curves / degradation of battery, you can install the free LucidLogger based on TeslaLogger:
