Gravity Air Suspension range published!
Lowest
See if you see camber changing as it goes up and down if you get the chance.
communicating with driver difficult so pushed the buttons on my own and did not measure anything but height drop
Lowest
In both one of the shots above and this one I believe I see noticeable positive camber on the rear wheels at max ride height.
That look goes away when the car is lowered:
Maybe we can get some additional angles of the wheels to confirm.
Join my group, my phone is giving me a hard time posting photos here
Thanks. So these screen shots from your video look like the opposite. So I can’t tell…
Finger math told a different story
With the shading in the software image, it's somewhat hard to locate the exact top of the tire.
Also, the software image provides a ground clearance measurement.
I think we (or maybe just me) have been thinking of the distance between the lower part of the body panel and the top of the tire, not ground clearance.
Ground clearance distance does make more sense to know when you think about it from a driving perspective versus the overall apperance.
The driving perspective is all I personally care about. I want whatever efficiency improvement might come from hugging the ground a bit more at highway speeds, but the ability to rise up high when I'm going slow in the snow. That said, I have found the discussion speculating how suspension/wheel geometry may vary with ride height to be interesting. I'm not sure I'm discerning enough of a driver to judge the difference, so I guess I'm content to assume that the Lucid engineering team made a good judgement about the various tradeoffs.
