What does “Ready” mean?
RMSko
Lucid Air Touring
Every time I stop there is a little message that comes up that says “Ready” and then it changes to “Hold”. I have it set to hold and I know what that means. I just don’t know what ready is intended to mean. Anyone know?
It means it's ready!
Why does it need to tell you that?
Sorry but ready for what? To change gears?
Ready to move, meaning not in park. And no errors/issues with drive. It is probably a superfluous message in reality...
Yes, according to the manual it just means it is ready to drive (whatever that entails) and isn't moving yet.
Thanks guys and I agree it’s superfluous
To indicate that the car is “switched on” and ready to move, which is only visible after you hit the brake after entering your car and all the system checks go through.
It won’t show Ready if there is an issue of some kind; the frunk is open, or something… even if the car is in D.
Interesting, I have had the car balk at going into drive if anything is open, or not open anything in D. I suppose it's possible to manually open the doors.
There have been reports that the car still drives (at a reduced speed of a maximum of around 15mph) even though it loudly alarms that the hood is open (it's not in real life; it's just the sensor issue!)
Many EVs display "Ready" because drivers are accustomed to the classic ICE "creep" behavior where the vehicle moves on it's own when the foot brake is released.
When "Hold" is displayed it indicates that the brakes are being applied by the car to hold the vehicle in position. When you hit the accelerator you should be able to feel/see the brake pedal let off.
