WearOS app for Lucid Motors' vehicles
Out of curiosity, can this app also act as a key for the car?
Won’t be a key but what’s awesome is that it’ll wake the car if it has been in deep sleep so when you get to the car with your mobile key, it works as we expect the mobile key should to work. No more waiting for a minute or so fiddling with the phone app by the car to wake up.
Another use case today was opening the frunk from the watch as I approached the car with groceries versus pulling my phone out, waiting for the car to wake, and clicking open frunk from the mobile app. Much easier to do from the watch face when I have it as complication on my Galaxy Watch. Very happy with what @DeaneG has built in even this first version! 🥰
Oh, I hadn't thought about adding an app shortcut to a complication on my everyday watchface. Good idea!
When I get a chance, I think I'll work on fixing the truthfulness of the button's state indicator to eliminate those tens of seconds' inaccuracy after a button push. I'll aim to display a spinning circle indicator until the state returned from the cloud API matches the button's intent, with a timeout in the event of bad connectivity, similar to Lucid's phone app.
Here’s a quick video of how simple it is.
Video
Looks great! Does your watch have a 40mm display size? I can see that the confirmation button need to be fixed so that the text doesn't wrap.
I chose to keep the display elements the same dimensions for any watchface size and just adjust their spacing. I could make them proportional instead, or use a checkmark and an X instead of Confirm and Cancel.
Looks great! Is that a 40mm display size? I can see that the confirmation button could be made smaller.
I chose to keep the display elements the same dimensions for any watchface size and just adjust their spacing. Maybe I should make them proportional instead.
That was going to be my next feedback to you. It’s 46mm display Samsung Galaxy Watch 8 Classic. I knew you were building around your Pixel Watch so didn’t think it major.
1. Occasionally, it loads up the login status to either refresh or logout as options for a second as you see in the video. It doesn’t happen all the time.
2. The confirm font is a little big so it skews the graphic on the options for the three actions that require it.
As an aside for those with careers in software, I was a bit shocked to be typing at a CLI in a terminal window to get simple things done while building this app. I first did that almost exactly 50 years ago and am surprised that's still the process. The terminal window I'm using doesn't even support cut or paste.
I keep telling everyone how little has changed while so much has changed
It's true, we still basically use the equivalent of an abacus
Is there any risk from Lucid asking the app to be pulled? The saying "No good deeds something something"
I would say is to make an open-source GitHub repo with all the necessary legal jargin that Gemini or your AI of choice can spit out. Let people build on your work versus worrying about how to gatekeep it.
They could, but it's unlikely, as long as it isn't confusing; don't use the Lucid logo/bear, ensure it is very clear it's a third-party app, etc. They still could because it uses an unpublished API, bit I highly doubt they would.
Plus, I'm sure @marqie could advocate to the right people if it became an issue (they have not said a peep, ever, about HA other than being excited about it, for example, so I don't see why they'd start now)
