- Jul 6, 2022
- LUCID GT
It's a real failure. You'll likely need a component (or more than one) replaced. A reset may help you get the car driving again to get it to a safe spot.No signs of any other issues for quite some time and it hit me today with two faults together at the same time at 9800 miles. Are these some mechanical issues or they are sensors failing?
Thanks. I called customer care and they arranged a towing but never told me to reset. Anyways now its waiting for someone to have a look at it.It's a real failure. You'll likely need a component (or more than one) replaced. A reset may help you get the car driving again to get it to a safe spot.
If one motor fails it has absolutely zero bearing on the other. Could be the HV battery, the coolant recall, or a list of other things too, depending on if it got its services or not.Having same issue with used 22 GT 29k miles after 6h drive home from dealer. Waiting for tow but usually a hardware motor swap required? Likelihood of the other motor failing eventually?
