Tire/Wheel Discussion
Tire Rack says that their search filters only generate sets of staggered tires that are compatible. (They will, however, sell a set their filter doesn't produce that includes two different tires if the buyer signs a liability waiver.)
lol. They’ve sold me a few sets of 235/40/18 and 305/30/19s for a ‘69 911 and I’ve never heard of this waiver. It’s a more recent addition, obviously.
Frankly I don’t believe the Tire Rack has the info to accurately judge compatible sets for specific cars. It’s great that they (or the manufactures?) are flagging potential incompatibility, because there are numerous other areas we didn’t even get to. Examples: Porsche GT car tires often have a fraction of the tread void area of more general tires of the same type. If mounted only on one axle this can lead to sudden snap spins due to uneven hydroplaning when it rains. Or sidewall stiffness which impacts total spring rate and hence cornering balance. Or stacked rubber compounds that are designed to optimize grip as the tire wears. Or different amounts of silicas that impact wet vs dry grip, potentially changing balance from understeer in the dry to oversteer in the wet or vice-versa. The list goes on. And on, and on.
You begin to understand why, as long as the tire design is relatively new, I recommend going with OEM tires as long as the design performance objectives are aligned with yours. Optimizing this stuff is a full time job, and doing it correctly requires data civilians don’t have access to. Black Magic. So while I’ve personally done some of this with varying degrees of success I typically recommend against it, knowing that those who know will ignore me. I’d feel much better if there were generic, not manufacture tuned tires available in these sizes that could predictably perform relative to one another. In the absence of that it seems largely a crap shoot without more info or more options.
I do get the point of the possible advantage of the largest wheels for mounting Pirellis. My two problems with those wheels are that they are not an aero design for range purposes, and there are no all-season tires available for them. So if I wanted to use all-seasons for cold weather road trips, I would have to buy an extra set of wheels as well as tires.
I have come close to just throwing in the towel and getting Continental DWS06 Plus tires for the mid-size wheels to run year-round. I absolutely loved the Continental DW tires on our first Tesla, and the DWS's are one of the very few ultra-high-performance rated all-seasons, and they get rave reviews as well. The problem is that even the best all-seasons will not match the straight-line traction and braking of the P Zeros, which kind of defeats the purpose of getting a Dream Edition if the traction control system is going to erase the power add. (I never drive sustained speeds above 80-85 mph, but I do love jack-rabbiting away from stops with clear road ahead.)
Tire Rack does stock non-manufacturer-tuned PZ4s in the two sizes for the mid-size wheels. But they do not show them as a suitable pairing, probably because the load and speed rating for the 265 is too low (SL / 104W).
They also show tuned tires that carry a "Sport" designation as well as the manufacturer tuning designation, perhaps indicating they at least share the same outer tread block for sport tuning vs. luxury tuning?
Interestingly, neither the Pirelli nor the Tire Rack website shows LM-tuned P Zeros in the 22/23" sizes for the largest Lucid wheels. So either the Gravities delivered in December with those wheels were shod with non-manufacturer-tuned tires, or those tires are not yet listed in the Pirelli or the Tire Rack catalogs.
Best of luck… No chance you’d get the range of OEM Michelins in my mind, but ditto with the Pirellis.
OEM Michelin specs below. Note the 1/32 deeper tread depth on the rear. The Lamborghini tires are likely closest given this, not sure if those are front or rear fitment.
The P Zero PZ4 is part of Pirelli's Electric tire line:
And it might actually be pretty good on range. Note its range test results in a 100-mile test (on a Tesla Model 3) against the class leader, the Hankook iON evo AS that comes on the smallest Gravity wheels. And it ran right in the pack with EV tires from Goodyear, Yokohama, and Bridgestone.
Also, Continental claims the DWS06 Plus is EV-tuned, whatever that means. Another Continental in the above test, also "EV-tuned", fared well in the range test, too. I don't know if that's any indication of the DWS range, of course. I did find that the DWS has a rolling resistance of 9.75 kg/to, but I don't know if there's any way to convert that to watt hours/mile.
@PetevB, I just noticed the tread widths on the Michelin Primacy specs you posted: 8" front and 8.9" rear.
That's almost an inch narrower on the front than the Pirellis (8.9"). In fact, the Michelin tread width on the rears is the same as the Pirelli tread width on the fronts.
Could that be correct, or is it an error?
Did you also notice that of the 285 Pirelli PZ4 options the only one marked Electric has an even narrower footprint? And that it's over half an inch narrower than the next narrowest option? No it's not an error- less rubber on the road reduces rolling resistance, so tires with efficiency as a goal will tend to be narrower. This is also why I'm confident saying that you won't get the range of the OEM Michelins.
It's easy to read a tire test and imagine at all tires of that brand name will perform similarly. Instead PZero PZ4 is really a marketing name for a tire platform which can come in a wide range of different constructions, compounds, tread patterns, etc. Just because some tires built on that platform can have low rolling resistance does not mean they all will. Lamborghini specified a wide footprint, deep tread blocks and quite likely the softest rubber and a grip optimized construction, all of which will hurt rolling resistance. Which is fine for Lamborghini, which doesn't care a whit about rolling resistance. An EV manufacture optimizing for range on the other hand would not make those choices, they'd spec a narrow tire with less tread depth and likely a different compound and construction. The PZ4 has a version like this and it's marked Electric. So they all say "Starbucks" but one's actually Pikes Place and another is Cafe Verona. They are not entirely dissimilar, but they are far from the same thing, and tasting notes from one (ie range tests) don't apply unless you're looking at the same flavor. You're looking at different flavors and assuming they will taste the same. Bad assumption.
My conspiracy theory is that OEM tires are just a way for tire companies to make extra money and for car manufacturers to lower costs. They sell the tires to automakers at a discount and then charge a premium to the consumer for tires that are only marginally different.
I put "generic" Michelin PS4S tires on my Model 3 and ran better lap times than my friend with Tesla specific PS4S. We've also driven side by side on a road trip and I got better efficiency even though I'm running 265/40R18 and he's running 235/35R20. Obviously not a scientific test but my point is that all this stuff is within the margin of error.
This is what is so frustrating about the information Lucid puts on its website. The Dream Edition order configurator says a Gravity with the Pirellis on the largest wheels will have the same range as the Michelins on the mid-size wheels -- 370 miles. You know that almost certainly can't be right, but you have no idea which figure is wrong or by how much.
It would be easy to assume they just didn't bother to test the range on anything but one of the Dream wheel/tire options, but yet they show a 410-mile range for the Hankooks on the smallest wheels. And they also show an array of ranges for the Grand Touring, with variances based on wheels, tires, and even seating capacity. So either they were just guessing on most of these, or they didn't do any actual testing of either the largest Dream wheels or the mid-size Dream wheels. (This raises another issue. The range for each wheel size on the Grand Touring changes with the choice of 5- or 7-passenger seating, as does the cargo capacity. But on the Dream Edition, the cargo capacity changes with seating choice, but the range doesn't. Why would going to 7 seats lose significant range on each of the Grand Touring wheel options but not on any of the Dream Edition's? Or is this all just sloppy website programming?)
This makes it devilishly difficult to figure out what tires on what wheel dimensions of what design might yield the the balance one wants between performance and range. In the old ICE days, range was far less a concern as gas costs didn't usually loom large in the equation for expensive cars. But with EVs, range can become a huge issue, especially as vehicles start dropping quickly below the 400-mile mark on cars in which you know you'll fall well short of EPA ratings in real-world road tripping. And when the manufacturer gives what is very likely bum information, you're really left behind the 8 ball.
lol. Yea, with some manufactures and some tires you’re likely right. No one with an off the rack BMW 325i’s going to tell the difference. But in other cases my experience says you’re very wrong. I’ve driven plenty of Porsche on N spec and non-N spec rubber, the difference between these is generally as obvious as a different alignment or a change in ride height. Which given that my GT3 PSC2s both had much less void area and nearly an inch more rubber on the road that the off the rack model shouldn’t come as a surprise. My editor would insist all cars had N spec rubber before we ran road tests back when I wrote about cars for a living…
More perspective here:
All that engineering effort but if you look at autocross results nobody is running Michelins. It just seems like the odds are low that any OEM tire is actually the best for any given customer's preferences, especially with a "jack of all trades" vehicle like the Gravity. For example for my Southern California "winter" tire I would like an all weather tire (3PMSF) with more sidewall durability for dirt roads.
For more geeking out, https://toptirereview.com/ev-range-estimator-tool-for-tires/ it will convert the rolling resistance to extra Kwh.
This caused me to take a look at the Michelin Primacy compared to the Continental DWS. The Primacy comes with a Lucid "LM1" designation, and it seems Lucid opted for a very narrow tread width to get the range. The DWS tread widths for the mid-size wheels are 8.9"/9.5". The Primacy LM1s are 8.0"/8.9".
Moreover, Michelin makes Primacies in the 265/45ZR21 size with a Volvo designation and a Polestar designation. Their tread widths are 8.9" (Volve) and 9.0" (Polestar), compared to 8.0" for the LM1s. That ~1" difference in width within the same tire line seems pretty extreme and suggests that either a lot of grip was given up by Lucid to get the range or other choices were made to recover the grip, such as tread compound? (This makes Lucid's claim that the Pirellis on the largest wheels and the Michelins on the mid-size wheels have the same range even more suspect.)
This choice seems to track what Lucid did in spec'ing the Hankooks for the smallest wheels. Yes, they have industry-beating range; but, based on testing and reviews, they really exact a price in performance in the wet.
This makes me even less inclined to keep the Primacy on the mid-size wheels if I stick with those wheels.
Rather than trying to find middle ground between range and handling on all three wheel options, it seems Lucid went all out on handling with the largest wheels and all-out on range with the smallest wheels (and maybe the mid-size wheels, too . . . a question muddied by that range claim). And this may be the reason for Eric Bach's plan to use the largest wheels on his personal car for local driving and the smallest wheels for road trips.
Because Michelin doesn’t make a dedicated autocross tire. The PSC2 is far too slow to heat for that, so all the extreme performance “200” treadwear rated (wink wink) dedicated AX tires crush it. But look at production car lap times, from Laguna to the ‘Ring, much closer to what car manufactures are typically tuning for, and you’ll see Michelins and PSC2s very well represented at the top of the class.
I suspect the debated 3PMSF vs standard all-seasons and decided the range sacrifice wasn’t worth it for most people, and standard all-seasons are sufficient for most of the country (which is generally pretty flat). Just a guess.
I've been coming across references to a new Pirelli P Zero that was not showing up in any tire retailer catalogs yet: the PZ5.
However, I just came across some used PZ5's for sale. They are marked "LM1", and the sizes indicate they came off of Gravities:
I’d get the listed mid size range rating out of your head. Take the Tesla Model 3: the 19” wheel option were a 3-4% range hit vs the 18” aero wheels, while the Performance’s 20” wheels were a 12% hit. Early Model 3 dual motors used identical motors and other hardware to the Performance, so this was almost exclusively tires and wheel aero.
The Gravity base wheels give 450 mile range. The big wheels are a 10% range hit. The middle tire will probably, like Tesla, be a 3-4% range hit vs base. We have lots of evidence that it’s closer to base tire than the top spec: the 540 TWR indicates a harder compound, good for rolling resistance but not performance. Ditto the narrow footprint. And given that Lucid tuned it and we can tell from the above their philosophy, the tire construction, etc will all be biased towards the “low rolling resistance” side. So my belief/ prediction is that the middle tires will have a 432-436 mile range, which is the real point of offering three options in the first place: one biased for range at the expense of performance, one vice-versa and something to split the difference. To image that they’d have the same range as the biggest wheel is to accuse the tires engineers who selected the mid size option at Lucid of complete incompetence. The smaller wheel is both lighter and more aerodynamic, so to equal the range of the bigger option the mid size tire must be both higher rolling resistance and, from the high treadwear rating and narrow footprint, simultaneously much lower in dynamic performance. “Uh, you’re fired…”
So the tires will be an improvement handing wise but not amazing. This was exactly the case for my Model 3 (I got the 19s). And yes, they proved a very good platform, over time, to accept PZero Electrics, etc, as they became available. So I’m not knocking the strategy, I’m just saying that expecting an actual range improvement out of the gate with the options currently available seems like false hope built on bad assumptions.
lol. Yep, makes sense. That biggest rim option is looking more interesting. I suspect that’s a very good tire in terms of performance vs rolling efficiency.
I'm thinking the same thing -- go back to my original choice of the 22/23" wheels, and just buy an extra set of wheels as well as tires for cold-weather road tripping.
I do wonder, though, why someone is selling used Gravity tires, as there are precious few alternatives available in the 22/23" size. Precious few Gravities, too . . . .
The smaller wheel is both lighter and more aerodynamic . . . .
This is another question to which Lucid gives no answer. More aerodynamic certainly; but lighter . . . I wonder?
With the Air Dream Edition, the 21" wheel unique to that version was listed as forged. No such claim was made for any of the other three wheel options for the Air.
This time Lucid has made no mention of any of the Gravity wheels being forged, even on the Dream Edition. However, the weight of the Gravity combined with the more "spindly" spokes of the largest wheels has made me wonder if they might not be forged?
"Tyre Reviews" has tested the PZ5 twice but not yet released the results. However, he hinted rather strongly in this video (6:28) that it might be really good:
The PZ5 is still not showing up on the Pirelli website, so I checked the German site mentioned in the video to see if the tire was available for the mid-size Gravity wheels. No luck.
My bet is a tuning shop. Either show (ie SEMA) or go (Pike Peak or track record SUV). Probably the latter, I bet the Gravity Dream with some Hoosiers would crush outright or electric SUV records all over the place, and if I was Lucid I’d get the best shop for that a car- PR value should be high. Those guys have no use for the stock rubber… or possibly the stock rims too. Maybe see if those are for sale?
Even if it’s heavier the fact that the rim is close in means the gyroscopic effect and hence energy to accelerate, etc, will almost certainly be less.
