Tire valve stem stuck inside hubcap?
EZEVDriver
OC
Air Touring, Model X
T8ABP862
After seeing a tire inflation alert on the dashboard, I dutifully began to inflate each tire to the recommended 49psi. However, the driver side front tire had its valve stem pushed back and lodged against the hubcap. While I might be able to thread a string around it to pull it back, I don't want to try it if that will cause any damage. Not trying to deflect blame, but the last time it was inflated was by Lucid mobile service.
Any suggestions?
