- Mar 7, 2020
- Naples, FL
- Air DE-P, 2 Gravity DEs
- Air DE Number
- 395
- Gravity DE Number
- 067
238
- 033M4EXG
Seeing Derek Jenkins wearing a baseball cap while driving the Air in Florida has left me musing about sun control in the car. When I first saw the new sun visor design, I assumed there was a full panel glued to the windshield so that when you dropped the visor down you would roughly double the surface area providing sun blocking. That turned out not to be the case. So we are left with a situation where the area from which you can block direct sun glare is no larger than the visor itself. When driving into late-afternoon sun that leaves you with very limited ability to deal with the changing location of the sun relative to the windshield as the car moves.
It seems to me there would be several ways in which this situation could be improved.
One would be the fixed panel behind the visor that I first mentioned.
Another would be to use a "butterfly" visor of two hinged panels so that you could double the size of the visor by unfolding it.
Yet another would be to incorporate a rigid slide-out panel into the visor that could be used to almost double its surface area when needed. A variation of this would be to use two slide-out panels, one pulling down from the visor and one pulling up.
None of these approaches would significantly change the look of the visor or the canopy when the visor is in its stored position.
Having seen a video showing the power-operated side window sun screens in the rear doors, I'm wondering whether the front doors have a similar mechanism. ( can see no reason why they couldn't.
I have a feeling there will soon be an aftermarket for pop-in mesh panels for parts of the glass canopy and for clip-on visor extenders. For a car in the price range of the Lucid Air, that seems odd.
