- Nov 14, 2021
- Dream P
- Air DE Number
- 33
- Gravity DE Number
- 33
- R0YBCKIJ
Bummer, I just bought one last week at full price.
In a nutshell, Tesla non supercharger stations will charge other cars as long as you have a converter - one of which is the Tesla Tap.Could some explain the Tesla Tap please? What does it do?
I thought Tesla charging stations would not allow non Teslas to charge there…..
(1) Which size is the correct/best to buy on that site for a AGT?In a nutshell, Tesla non supercharger stations will charge other cars as long as you have a converter - one of which is the Tesla Tap.
Also for people who have Tesla home chargers to charge their other (better) EV, the Lucid!Could some explain the Tesla Tap please? What does it do?
1. I chose the 80amp MiniTap to be safe, as some times you will find a higher rated Amp Tesla destination charger to use. This can be a handy tool if you go on long road trips. I am planning a 7 state National Park road trip in June and will have some charging challenges in Montana, Wyoming & South Dakota. I may have to use some Tesla destination chargers along the way.(1) Which size is the correct/best to buy on that site for a AGT?
(2) Where does one find a online map of the Tesla non- super charger sites?
Totally agree with these. PlugShare for local search and ABRP for distance.1. I chose the 80amp MiniTap to be safe, as some times you will find a higher rated Amp Tesla destination charger to use. This can be a handy tool if you go on long road trips. I am planning a 7 state National Park road trip in June and will have some charging challenges in Montana, Wyoming & South Dakota. I may have to use some Tesla destination chargers along the way.
2. I use PlugShare and ABRP apps. That show all the available chargers.
A Better Route PlannerI have downloaded Plug Share,Electrify America and Charge Point. What is ABRP?
Agree with the 80 amp TeslaTap adaptors for exactly the above ^^^^^^^1. I chose the 80amp MiniTap to be safe, as some times you will find a higher rated Amp Tesla destination charger to use. This can be a handy tool if you go on long road trips. I am planning a 7 state National Park road trip in June and will have some charging challenges in Montana, Wyoming & South Dakota. I may have to use some Tesla destination chargers along the way.
Can non Tesla use these charging stations?In a nutshell, Tesla non supercharger stations will charge other cars as long as you have a converter - one of which is the Tesla Tap.
Yes to destination chargers. No to super chargers. Destination chargers are usually located at hotels, restaurants, etc and would be controlled by the property owner. Would just need an adapter to use if not a Tesla.Can non Tesla use these charging stations?
Thanks.Yes to destination chargers. No to super chargers. Destination chargers are usually located at hotels, restaurants, etc and would be controlled by the property owner. Would just need an adapter to use if not a Tesla.
Alex mentioned the tight fit of the mini Tesla Tap. He found the areas that were binding and sanded those spots. Subsequently, the mini goes on and off without difficulty. You might message Alex for more information if needed. @Alex also has the non-mini version of Tesla Tap and it does not bind like the mini.I have one of the "mini" versions and it is quite difficult to use because of an extremely tight fit on the Tesla connector end. It's body-weight-press-it-against-the-ground tight to mate, and wiggle-it-for-a-whole-minute tight for unmating. I'm a 165lb male who lifts weights. There's no way my wife could use the product. If I were buying again I'd get one of the non-mini versions and hope it fits better.
Thanks, will do.Alex mentioned the tight fit of the mini Tesla Tap. He found the areas that were binding and sanded those spots. Subsequently, the mini goes on and off without difficulty. You might message Alex for more information if needed. @Alex also has the non-mini version of Tesla Tap and it does not bind like the mini.
