- Jan 3, 2022
- Santa Clara County, CA
- Air GT, XC40 P8 EV
While I’m here… can someone explain to be like I’m five why the max charge rate is 250 kW even from EA 350 kW...
and
Hello forum friends!
With the most recent software update Lucid made changes for battery temperature management as well as preconditioning at low battery levels and I wanted to see how this affected the charging curve. I've gathered a little bit of data that I wanted to share with everyone. Before I do, I just want to note some disclaimers and limitations. Also note this will be a lengthy post and will be split up across multiple entries.
- Data was recorded by hand or transcribed from video, so there may be some minor errors in my dataset. Often charging power would fluctuate within...
