- Dec 17, 2021
- Greenville, SC
- Sapphire 1 of 6
I hope Lucid takes your incident very seriously and investigates.
That is probably the case when there is an accident where unintended acceleration causes the car to hit an object but these incidents have the car braking after the feeling of acceleration (either regen braking stops which makes it feel like the car accelerated - which I think is the case or the car accelerated). If they hit the wrong pedal, they would have quickly accelerated into the object as they pressed harder to try to stop. Since the car does brake after the momentary feeling of acceleration, it seems like rather than the regen being additive to the braking effort, the regen is missing.Not doubting anyone, but especially with one pedal driving 99.99 percent of the time in car data shows the human pressed the wrong pedal.
this is how victim blaming startsNot doubting anyone, but especially with one pedal driving 99.99 percent of the time in car data shows the human pressed the wrong pedal.
a reasonable explanation but why did the car go off the regen when the collision warning appeared? shouldn't it stay on because my car is set to high regen and my foot was off the accelerator? as i described in my original thread, i'm pretty sure i got the collision warning after i started applying the brakes so your theory somewhat makes sense (i.e, i took my foot off accelerator, high regen started, i braked lightly, collision warning came on, high regen turned off which caused the car to lunge and i braked harder).It happened with me as well a few times as well. As soon as the car has a collision warning it lets go of the Regen braking and depends solely on the car brakes which probably is causing this thus throwing us off regarding how much to depress the brake pedal
Honestly it threw me off a few times as well. It happened with me in stop and go traffic. Only reasonable liability thing I can think of is Auto Braking as it might not know if motor Regen is working or not ( in worse case scenario where motor fails) so it only wants to depend on brakes for emergency collision system or maybe regulatory. It definitely throws you off where if not paying attention will definitely cause an accident.a reasonable explanation but why did the car go off the regen when the collision warning appeared? shouldn't it stay on because my car is set to high regen and my foot was off the accelerator? as i described in my original thread, i'm pretty sure i got the collision warning after i started applying the brakes so your theory somewhat makes sense (i.e, i took my foot off accelerator, high regen started, i braked lightly, collision warning came on, high regen turned off which caused the car to lunge and i braked harder).
i think you have a good explanation (i.e, regen and auto braking working as separate systems) but Lucid should document this behavior and put it on the manual.Honestly it threw me off a few times as well. It happened with me in stop and go traffic. Only reasonable liability thing I can think of is Auto Braking as it might not know if motor Regen is working or not ( in worse case scenario where motor fails) so it only wants to depend on brakes for emergency collision system or maybe regulatory. It definitely throws you off where if not paying attention will definitely cause an accident.
I don't remember that happening in my model x ( sold in 2019) so don't even remember anything about the car other than being louddd inside
A Lucid member reached out to me and got the VIN, and time it occur today. Hope it helpedi think you have a good explanation (i.e, regen and auto braking working as separate systems) but Lucid should document this behavior and put it on the manual.
If the car is behaving as expected, any press of the brake disables the accelerator. I tried a few different scenarios on the way to work. Every time as soon as I touched the brake the accelerator was cut.Nope.
Just curious.... are you on the latest and greatest software update? 2.0.24?I experienced this today
Pretty certain I was not pressing the Brake pedal when the warning came on
the loss of regen was like the car was suddenly “running away”
disconcerting to say the least
+1 just happened today for the first time.I experienced this today
Dang that’s scary.+1 just happened today for the first time.
I was coming off of the highway, in full regen. There was a car stopped at the light ahead, I knew I'd need brake input eventually but I let the car regen as much as I could.
Then it happened just as I was about to gently add brake pressure. I got the forward collision warning, and then I started my brake input and the car started to lurch forward (definitely just regen cutting out), now obviously I had not planned for not having regen suddenly so I really had to slam the brakes to get stopped short of the car in front. Went into ABS for the first time.
Thankfully, the brakes on the Air are stellar.
Idk if it's safety issue per se but it's a drivability issue for sure. Gets your blood pumping though.
Someone just reported that as being an issue so I hope they will investigate and address quickly.Dang that’s scary.
