- Oct 27, 2024
- Hunterdon County, New Jersey
- 25 Air GT/Blue/SCruz/19"
- GZ3PGK37
Not sure it really matters in terms of the exact mathematical function…it goes up way faster than linear…
I just got my car last week and I’ve also been averaging about 3.0 miles per kWh. It’s the winter here and so I expect that will improve in the summer.I generally get about 70% of the stated range. I average about 3.0 miles per kwh.
Most of my driving is very short distances and even though my car is garages, it’s cold. I keep the cabin about 71, I have the 20” wheels and yes, I do have the glass roof and so I’m not at all surprised at the 3 miles per kWh - with my Audi Q8 I was typically only getting 1.5 in the winter.Thank you for your perspective, but if you can provide more specifics such as the speeds you drive and how warm you keep your cabin it would be helpful. I see you have a Touring. Does it have the glass roof or the metal roof? IMO a metal roof will measurably reduce climate control use.
Just don't use the AC if you are looking for better fuel economy...Today it was 28 degrees F with a howling wind and I went out for a hilly drive on roads with 45-50mph speed limits. I drove only 30 miles. BUT I preheated the car before leaving and the battery had just finished charging so I didn’t even need the heat on (it was a bright sunny day) and I averaged 4.45 m/kWh. 25 AGT metal roof 19” wheels…
I am really looking forward to seeing how efficient the car is in warm weather!!!
In my personal real-world driving across California on routes from Hesperia to Santa Barbara and San Diego, I’ve never come close to achieving the EPA-rated range in my 2022 Lucid Air GT. Even under ideal conditions, cruising at 70 mph on sunny 80-degree days with properly inflated 19-inch all-season tires, the best I’ve personally achieved is 485 miles, far short of the 516 some reviewers have been able to achieve.You need to change your tires/wheels. The 20s are summer tires and shouldn't be driven in temps under 45F. You risk catastrophic failure of the tire rubber in cold weather.
I assume you mean etron suv? 1.5 miles/kw in winter?Most of my driving is very short distances and even though my car is garages, it’s cold. I keep the cabin about 71, I have the 20” wheels and yes, I do have the glass roof and so I’m not at all surprised at the 3 miles per kWh - with my Audi Q8 I was typically only getting 1.5 in the winter.
I think they don’t market it because that would be admitting their pre-2005 numbers are mostly BS in all but nearly perfect conditions. There’s no way with massive efficiency changes the pre 2025 and 2025 models really have the same range.Prior to 2024 the EPA tests were different. The 2025 Lucid’s were the first to be tested under EPA’s new protocol (which is more stringent and therefore more realistic).
Based on my personal (admittedly limited) experience with both a 2022 AGT and a 2025 AGT, I believe that the 2025’s CAN achieve their EPA rating in reasonably mild climates with reasonable driving practices and the 2024 and earlier cars CANNOT.
Many aspects of the 2025 AGT have been upgraded…battery chemistry and capacity, heat pump, electromagnetic motor efficiency, thermal management…these things are real and add up to an appreciably more efficient package. My own recent experience has yielded over 20% more efficiency out of the 2025 compared with the 2022. While I wouldn’t bank on that full 20% being accurate, I am 100% certain that the efficiency improvements in the 2025 AGT are meaningful and that the real world range has improved WELL NORTH of 10%…
What I do find strange is why Lucid has not marketed this. When you take the world’s most efficient EV and improve its efficiency and range significantly, why not actively and loudly market it?
Yes, e-tron SUV SB and got at best 1.5 in the winter and often lessI assume you mean etron suv? 1.5 miles/kw in winter?
